Date/Time: Thu, 10 Sep 2026 06:48:06 +0000
right margin
View Count: 1449
| [2014-10-21 00:52:55] |
| User28682 - Posts: 233 |
Hi, Is there a way to create a permanent right margin (space) on a chart so it doesn't run all the way to the right edge? Thanks Tom |
| [2014-10-21 04:52:56] |
Yes. This is documented on this page: Working With Charts: Scrolling The Chart and Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
