Date/Time: Wed, 25 Nov 2026 22:26:22 +0000
v2862 - Background spreadsheet windows showing when changing chartbooks
View Count: 727
| [2026-01-13 21:59:07] |
| User273277 - Posts: 145 |
I updated to version 2862 from 2813 today. I use F7 and F8 to move back and forth between chartbooks quickly. I have 4 windows in each of 2 chartbooks. 2 of the windows in each chartbook were always set to be hidden by the other 2 windows. But now every time I move between chartbooks, the 2 background windows move to the foreground over the 2 windows that I had set to be the foreground. Then I select the 2 windows that should be in the foreground, hiding the other 2 windows as they should be. I move to the other chartbook and back. And the background windows are now again in the foreground. This makes it impossible to quickly toggle between chartbooks. Is there a new setting I need to set for background windows? |
| [2026-01-13 22:10:21] |
When you state that the other charts were set to be "Hidden" what exactly do you mean? Are they actually open, but just covered? Or did you have them minimized? We think this may be related to having the windows you do not want to see "minimized". In which case, there is a new setting that controls what it means to have a window "minimized". Refer to the following: General Settings Window: MDI Child Window Minimize Method (List) (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings) The default for this is "Minimize in Place", which we think is what you are seeing. Try setting this to "Hide Window" which actually completely removes the window as if the option for "Hide Window" were selected. Let us know if this is not what you want, and/or it does not work for what you are doing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-13 22:14:39] |
| Sierra_Chart Engineering - Posts: 25484 |
To solve this, adjust the order of these windows to become the highest in the list of Chart windows, in the Windows and Chartbooks list: Window, CB and CW Menus: Windows and Chartbooks (Window) The behavior you see now when switching Chartbooks is no different, than what you would see when you actually open the Chartbook when it is not already open. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-13 22:15:59
| [2026-01-13 22:30:08] |
Three of the windows are listed in the "Windows and Chartbooks" menu. Of the 3 windows listed, 1 of the windows I want to hide are there, and has been moved to the top. It is now hidden properly when I move between chartbooks. Thank you. However, the spreadsheet window is not showing in that list of windows, so I can't change the order. Is there another way to change the order of the spreadsheets? Date Time Of Last Edit: 2026-01-13 22:31:16
| [2026-01-14 03:19:08] |
We think this may be related to having the windows you do not want to see "minimized". In which case, there is a new setting that controls what it means to have a window "minimized". Refer to the following: General Settings Window: MDI Child Window Minimize Method (List) (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings) The default for this is "Minimize in Place", which we think is what you are seeing. Try setting this to "Hide Window" which actually completely removes the window as if the option for "Hide Window" were selected They are open, but just covered. They were not minimized. This is for a spreadsheet window. The other regular chart window is staying hidden now by changing the display order. I just tried setting the MDI Child Window mimize method to hide window, and also to minimize to bottom. Both just show up in the bottom left of the chartbook screen when I change to another chartbook and come back. Is there something special about spreadsheet windows that need to be minimized/hidden differently? |
We think this may be related to having the windows you do not want to see "minimized". In which case, there is a new setting that controls what it means to have a window "minimized". Refer to the following: General Settings Window: MDI Child Window Minimize Method (List) (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings) The default for this is "Minimize in Place", which we think is what you are seeing. Try setting this to "Hide Window" which actually completely removes the window as if the option for "Hide Window" were selected They are open, but just covered. They were not minimized. This is for a spreadsheet window. The other regular chart window is staying hidden now by changing the display order. I just tried setting the MDI Child Window mimize method to hide window, and also to minimize to bottom. Both settings result in the spreadsheet window being displayed in the bottom left of the chartbook screen when I change to another chartbook and come back. Is there something special about spreadsheet windows that need to be minimized/hidden differently? Date Time Of Last Edit: 2026-01-14 05:00:31
| [2026-01-15 18:36:44] |
Any ideas on how to prevent the spreadsheet window from popping into the foreground when switching between workbooks?
| [2026-01-15 18:58:51] |
Are these spreadsheet windows, associated with a spreadsheet study? We are not able to reproduce this. They do stay in the background. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-15 19:20:45] |
It is a "DefaultSpreadsheetSystemAlertStudy". Attached are 3 partial screenshots. The first one (leftw1rightw2fgsp.png) is a chart on the left, a chart on the right, and the spreadsheetsystemalertstudy spreadsheet window in the foreground. Then in the second screenshot (hidesp.png), I clicked on the two chart windows, hiding the spreadsheet window. The third screenshot (leftw1rightw2fgsppartialafterswitching.png) has the two charts in the background, but the spreadsheet is now in the foreground over one of the chart windows after pressing F7, then F8 to switch between chartbooks. Date Time Of Last Edit: 2026-01-15 19:26:24
| [2026-01-15 19:24:02] |
The windows and chartbooks settings do not show the spreadsheet window, so I can't set the order to hide it.
| [2026-01-16 14:19:38] |
Do the attachments help to see what is happening? This is reproducible every time.
| [2026-01-16 16:26:25] |
We have a note to look into this. We have not yet had time to get to this. Give us a few days.
| [2026-01-20 20:54:52] |
We understand the problem now. A solution to this will be out in version 2867 to be released now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-20 21:22:26] |
Thank you. Another Sierra Chart support win. You guys are great.
