Date/Time: Wed, 25 Nov 2026 22:21:10 +0000
Footprint settings
View Count: 555
[2026-01-13 17:08:03]
User977892 - Posts: 10
Hello, i was trying to adjust my footprint. I wanted to see automaticaly some numbers colored in the column 2. I wanted to compare them diagonally, and to color it only when one of them was 300% bigger than the other. Imagine : https://www.sierrachart.com/image.php?Image=1768323745303.png
Thanks in advice.
[2026-01-13 18:26:08]
The concept for what you want to do is covered in the documentation here:
Numbers Bars: Display Ask/Bid Imbalance
You just need to apply it to the text coloring and not the background.
