Date/Time: Wed, 25 Nov 2026 22:21:05 +0000
P/L BOX NOT CORRECT
View Count: 384
| [2026-01-13 01:41:25] |
| User790442 - Posts: 3 |
Hello, my trade window the P/L is right but the one below it the one with the "When I start trading is giving me a final P/L which is not even right especially when i just start my day I tried fixing it follow the CHART- CHART SETTINGS -TRADE There is none there to correct it. kindly fix it for me sine im not able to track my real time P/L thank You |
| [2026-01-13 15:22:15] |
We do not know what you mean by "the one below it the one with the ..." is referencing. If you are referring to your Trade Activity Log, then what exactly are you looking at in that window that is not correct. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-13 16:51:05] |
THE "D " ABOVE THE ACCOUNT NUMBER THE FINAL P/L WAS NOT CORRECT , AS SOON AS I START TRADING EITHER I BUY OR SHORT IT GIVES RIGHT AWAY A P/L WHICH I DONT HAVE ANY IDEA WHERE IT COMES FROM SO I HAVE TO RELY ON TRADE ACTIVITY OR TRADE ACCOUNT, TRADE WINDOW THE ONE THAT I CAN ATTACHED OR RETACHED NEXT TO THE CHART |
| [2026-01-13 16:56:56] |
That is the "Daily P/L". Refer to the following: Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
