Date/Time: Wed, 25 Nov 2026 22:26:23 +0000
Times & Sales Data
View Count: 980
[2026-01-12 21:16:01]
User882391 - Posts: 98
Hello, Happy New Year! can you please advise on the below
1) I am looking to extract the Times & Sales data for ES either from foot print chart to CSV file.
2) I got the TIME & SALES Window open but unable to download the data to CSV format.
Please advise best process to download the data in CSV file format for example for Jan 12th data.
Regards,
[2026-01-12 21:25:15]
The only way to export the Time and Sales data would be to create a 1 tick (1 trade) chart and then export that information using "Edit >> Export Bar Data to Text File".
Refer to the following:
Chart Settings: Number of Trades Per Bar (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings >> Bar Period Type)
Edit Menu: Edit >> Export Bar Data to Text File
Otherwise, to get at the actual Time and Sales information itself, you would need to use a custom study. Refer to the following:
ACSIL Interface Members - Functions: sc.GetTimeAndSales()
[2026-01-16 21:20:47]
Edit Menu: Edit >> Export Bar Data to Text File tried that but nothing is extracted
Still not able to extract time & sales data, ideally looking to extract in CSV format the data so i can at speicific time how many lots were bought & sold/ transacted.
[2026-01-19 17:33:16]
You have to select this when you have an active chart.
When you select the option, you are presented with a window to enter the filename to save to, along with where you want to save it. Are you not getting this window?
