Date/Time: Wed, 25 Nov 2026 22:21:10 +0000
Custom Text Drawing Buttons
View Count: 426
| [2026-01-10 14:45:04] |
| nicktrader - Posts: 817 |
I have created 10 different “Custom Text Drawing” buttons in a control bar. For example, if I click on the first one, the second one is immediately set to “active,” and if I now click with the left mouse button in the chart, the text of the second button is immediately displayed. Then the third one is activated, and so on. Clicking with the right mouse button neutralizes the “activation” of the buttons. I only want to click once, and further activation should be disabled immediately afterwards. Where can I disable this? Thank you very much. |
| [2026-01-12 15:56:43] |
We think you are looking for this setting: Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options) Just keep in mind that this affects all tools. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
