Date/Time: Wed, 25 Nov 2026 22:21:10 +0000
How to stop study lines from diagonally crossing into the next session?
View Count: 378
| [2026-01-09 14:53:56] |
| LongShortz - Posts: 53 |
Is there a way to make study lines terminate at the end of the session when the data for that study resets? Currently, studies like VbP will have VA or POC lines crossover into the new session. I've tried different line types in the subgraph settings but can't find a way. Is there a chart setting or something I haven't found yet?
| [2026-01-09 16:52:52] |
Try a Draw Style of "Dash". This will prevent the line being drawn between sessions, but it may make the line look "choppy". You will need to decide which option works best for you. Refer to the following: Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
