Date/Time: Tue, 27 Oct 2026 17:53:52 +0000
rithmic / orders not sending
View Count: 517
[2026-01-07 21:19:09]
tradewerx - Posts: 18
hello, i am trying to place orders using the trade window. i get no response from sierra when doing so. no message log info, no order executed, nothing. trade is NOT locked. when i switch to sim i am able to place orders. any idea what could be causing this?
[2026-01-07 21:43:23]
John - SC Support - Posts: 48342
If your "Trade >> Trade Service Log" and your "Windows >> Message Log" are actually blank, then select "Global Settings >> Message Categories" and set everything in there to "Yes". This was an issue with a recent release.
In either case, then try to place a trade and after you have a problem, get us your "Trade Service Log" by following these instructions:
Support Board Posting Information: Providing Lines From Trade Service Log
[2026-01-07 21:47:44]
Message log now fixed. This is what Trade Service Log is reporting. 2026-01-07 13:02:53.200 | Rithmic Direct - DTC | Requesting trade accounts from server.
[2026-01-07 21:50:18]
Id like to add. earlier i was executing on a different platform. when i logged into sierra i was able to see open position / orders, but still unable to place / move orders. i have since signed out of the other platform and only have sierra connected, still unable to place orders.
[2026-01-07 22:01:04]
We need to see your entire Trade Service Log. The line you provided just tells us that the system is connecting to Rithmic.
Also, you need to try to place a trade first and if it fails, then get us the Trade Service Log. Follow these instructions to get us the log:
[2026-01-07 22:17:04]
2026-01-07 13:02:48.215 | Trade activity files set size: 110
2026-01-07 13:02:48.223 | Rithmic Direct - DTC | Processed connection points. Count: 474
2026-01-07 13:02:48.260 | Reading Internal Order ID file.
2026-01-07 13:02:48.261 | Reading Trade Orders file.
2026-01-07 13:02:48.261 | Reading Trade Positions file.
2026-01-07 13:02:48.262 | Reading Trade Account Data files.
2026-01-07 13:02:48.264 | Software version: 2803 64-bit
2026-01-07 13:02:48.264 | Primary Thread ID: 17124
2026-01-07 13:02:48.264 | Usage end date: 2026-01-15
2026-01-07 13:02:48.264 | Enabled for: Advanced Features 2.
2026-01-07 13:02:48.264 | Enabled for: Sierra Chart Historical Data Service.
2026-01-07 13:02:48.264 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-01-07 13:02:48.264 | Enabled for: Delayed Denali Exchange Data Feed.
2026-01-07 13:02:48.264 | Enabled for exchange2: CME (Trading Account Required)
2026-01-07 13:02:48.264 | Enabled for exchange2: CBOT (Trading Account Required)
2026-01-07 13:02:48.264 | Enabled for exchange2: COMEX (Trading Account Required)
2026-01-07 13:02:48.264 | Enabled for exchange2: NYMEX (Trading Account Required)
2026-01-07 13:02:48.264 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-01-07 13:02:48.264 | Current selected Data/Trading service: Rithmic Direct - DTC
2026-01-07 13:02:48.264 | Custom symbol settings values: enabled
2026-01-07 13:02:48.264 | Chart Update Interval: 400
2026-01-07 13:02:48.264 | Intraday Data Storage Time Unit: 0
2026-01-07 13:02:48.264 | Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00)
2026-01-07 13:02:48.264 | 2026-01-07 21:02:48 Local computer time in UTC
2026-01-07 13:02:48.264 | 2026-01-07 13:02:48 Local computer time in SC Time Zone
2026-01-07 13:02:48.264 | 2026-01-07 21:02:47 Server time in UTC
2026-01-07 13:02:48.264 | Local computer UTC time and Server UTC time difference: 0 seconds.
2026-01-07 13:02:48.264 | Program path: C:\SierraChart\
2026-01-07 13:02:48.264 | Data Files path: C:\SierraChart\Data\
2026-01-07 13:02:48.264 | OS Version Number: 10.0
2026-01-07 13:02:48.264 | Locale Setting: C
2026-01-07 13:02:48.264 | Crash reporter started: true
2026-01-07 13:02:48.287 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2026-01-07 13:02:48.287 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2026-01-07 13:02:48.287 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89.
2026-01-07 13:02:48.292 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2026-01-07 13:02:48.323 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:02:48.422 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2026-01-07 13:02:48.422 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2026-01-07 13:02:48.503 | Mapping MNQH6.CME to MNQH26. Service code: cme
2026-01-07 13:02:48.503 | Using symbol data fast lookup vector
2026-01-07 13:02:48.581 | Received 5 login tokens.
2026-01-07 13:02:48.751 | Symbol settings MD5 received. Request ID: 1.
2026-01-07 13:02:48.751 | Symbol settings are up-to-date for rithmic_v2.trading.
2026-01-07 13:02:49.056 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | Number times message added: 1
2026-01-07 13:02:49.057 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 110576
2026-01-07 13:02:49.058 | Rithmic Direct - DTC | Processed connection points. Count: 474
2026-01-07 13:02:49.058 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2026-01-07 13:02:49.058 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-01-07 13:02:49.058 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2026-01-07 13:02:50.787 | Requested user files to download.
2026-01-07 13:02:52.798 |
2026-01-07 13:02:52.799 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated
2026-01-07 13:02:52.799 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569
2026-01-07 13:02:52.799 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569
2026-01-07 13:02:52.868 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-01-07 13:02:52.868 | DTC Client socket (1) | New receive buffer size: 0
2026-01-07 13:02:52.868 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2026-01-07 13:02:52.942 | Rithmic Direct - DTC | Network connection to server complete.
2026-01-07 13:02:52.942 | Rithmic Direct - DTC | Starting socket receive thread.
2026-01-07 13:02:52.942 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-01-07 13:02:52.942 | Rithmic Direct - DTC | Sending logon request message.
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | Received logon response.
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | Server Name: .
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | Successfully connected.
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | Trading is supported.
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | Order cancel and replace is supported.
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | OCO Orders supported.
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2026-01-07 13:02:53.198 | Rithmic Direct - DTC | Connection to server complete.
2026-01-07 13:02:53.199 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-01-07 13:02:53.509 | Mapping MNQH6.CME to MNQH26. Service code: cme
2026-01-07 13:02:53.510 | Using symbol data fast lookup vector
2026-01-07 13:02:53.510 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 1 Service code: cme
2026-01-07 13:02:53.510 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 10048
2026-01-07 13:02:53.510 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 1
2026-01-07 13:02:53.511 | DTC Client socket (2) | Creating socket.
2026-01-07 13:02:53.511 | DTC Client socket (2) | New receive buffer size: 0
2026-01-07 13:02:53.511 | DTC Client socket (2) | Connecting to IP: 216.200.108.154.
2026-01-07 13:02:53.573 | Denali Data Feed | Network connection to server complete.
2026-01-07 13:02:53.573 | Denali Data Feed | Starting socket receive thread.
2026-01-07 13:02:53.573 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-01-07 13:02:53.661 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-01-07 13:02:53.661 | Denali Data Feed | Sending logon request message.
2026-01-07 13:02:54.194 | Denali Data Feed | Received logon response.
2026-01-07 13:02:54.194 | Denali Data Feed | Server Name: SC Realtime Server.
2026-01-07 13:02:54.194 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:02:54.194 | Denali Data Feed | Successfully connected.
2026-01-07 13:02:54.194 | Denali Data Feed | Trading is not supported.
2026-01-07 13:02:54.194 | Denali Data Feed | MarketDepthIsSupported: 1
2026-01-07 13:02:54.194 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26
2026-01-07 13:02:54.349 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946
2026-01-07 13:02:54.349 | Denali Data Feed | Received security definition for symbol MNQH6.CME
2026-01-07 13:02:56.010 | Files to Open on Startup | Opening file: S&P.Cht
2026-01-07 13:02:56.023 | Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffe366d0000
2026-01-07 13:02:56.308 | NQH6.CME/MNQH6.CME [C] 1 Min #9 | Reloading chart.
2026-01-07 13:02:56.309 | Starting DelayedDownloadMonitoringTimer
2026-01-07 13:02:56.309 | Starting HDTimeoutTimer
2026-01-07 13:02:56.309 | Added historical Intraday data request for NQH6.CME to the queue.
2026-01-07 13:02:56.310 | Triggering next historical data download in queue.
2026-01-07 13:02:56.310 | NQH6.CME/MNQH6.CME [C] 1 Min #9 | Waiting for historical downloads to complete with the IDs: 1,
2026-01-07 13:02:56.325 | NQH6.CME [C] 15 Min #5 | Reloading chart.
2026-01-07 13:02:56.325 | NQH6.CME [C] 15 Min #5 | Waiting for historical downloads to complete with the IDs: 1,
2026-01-07 13:02:56.338 | NQH6.CME [C] 5 Min #7 | Reloading chart.
2026-01-07 13:02:56.339 | NQH6.CME [C] 5 Min #7 | Waiting for historical downloads to complete with the IDs: 1,
2026-01-07 13:02:56.349 | NQH6.CME [C] Daily #1 | Reloading chart.
2026-01-07 13:02:56.349 | NQH6.CME [C] Daily #1 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2026-01-07 13:02:56.349 | NQH6.CME [C] Daily #1 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2026-01-07 13:02:56.745 | ESH6.CME [C] #4 | Reloading chart.
2026-01-07 13:02:56.749 | Added historical Intraday data request for ESH6.CME to the queue.
2026-01-07 13:02:56.749 | ESH6.CME [C] #4 | Waiting for historical downloads to complete with the IDs: 2,
2026-01-07 13:02:56.989 | ESH6.CME/MESH6.CME #2 | Reloading chart.
2026-01-07 13:02:56.998 | Mapping NQH6.CME to NQH26. Service code: cme
2026-01-07 13:02:56.998 | HD Request # 1 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme
2026-01-07 13:02:56.998 | HD Request # 1 | Download start date-time: 2026-01-07 10:08:47.000000. File last date-time: 2026-01-07 10:08:47.088000
2026-01-07 13:02:56.998 | HD Request # 1 | Using server: ds32.sierracharts.com port 10150
2026-01-07 13:02:56.999 | Socket (3) | Creating socket.
2026-01-07 13:02:56.999 | Socket (3) | New receive buffer size: 0
2026-01-07 13:02:56.999 | Socket (3) | Connecting to IP: 69.39.70.248.
2026-01-07 13:02:57.015 | NQH6.CME [C] Daily #1 | Chart data loading complete.
2026-01-07 13:02:57.092 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 2 Service code: cme
2026-01-07 13:02:57.092 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 2
2026-01-07 13:02:57.096 | Mapping ESH6.CME to ESH26. Service code: cme
2026-01-07 13:02:57.096 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 3 Service code: cme
2026-01-07 13:02:57.096 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 3
2026-01-07 13:02:57.096 | Mapping MESH6.CME to MESH26. Service code: cme
2026-01-07 13:02:57.096 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 4 Service code: cme
2026-01-07 13:02:57.096 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 4
2026-01-07 13:02:57.180 | HD Request # 1 | Setting DTC encoding to Binary VLS
2026-01-07 13:02:57.180 | HD Request # 1 | Sending historical data logon request message.
2026-01-07 13:02:57.194 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475
2026-01-07 13:02:57.194 | Denali Data Feed | Received security definition for symbol NQH6.CME
2026-01-07 13:02:57.194 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878
2026-01-07 13:02:57.194 | Denali Data Feed | Received security definition for symbol ESH6.CME
2026-01-07 13:02:57.194 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800
2026-01-07 13:02:57.194 | Denali Data Feed | Received security definition for symbol MESH6.CME
2026-01-07 13:02:57.303 | HD Request # 1 | Requesting Intraday data. Start date-time: 2026-01-07 10:08:47. Record interval: 0. Symbol: NQH26
2026-01-07 13:02:57.346 | ESH6.CME/MESH6.CME[M] #2 | StartDateTimeForLoadingOrderFills: 2024-12-31 00:00:00
2026-01-07 13:02:57.349 | ESH6.CME/MESH6.CME[M] #2 | Chart data loading complete.
2026-01-07 13:02:57.391 | HD Request # 1 | Decompressing data.
2026-01-07 13:02:57.490 | HD Request # 1 | Receiving Intraday data for NQH6.CME starting at 2026-01-07 10:08:47.009000
2026-01-07 13:02:57.756 | HD Request # 1 | Timestamp of first Intraday data file record written: 2026-01-07 10:08:47.354000.
2026-01-07 13:02:58.165 | Socket (3) | CloseSocket call.
2026-01-07 13:02:58.165 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-01-07 13:02:58.169 | Historical data download thread signaled to stop.
2026-01-07 13:02:58.169 | HD Request # 1 | Received 135729 Intraday data records from 2026-01-07 10:08:47.009000 to 2026-01-07 13:02:55.448002 (2.9 hours. Delay: 2.7 seconds) and wrote 135696 records for NQH6.CME
2026-01-07 13:02:58.176 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2026-01-07 21:02:55.448002
2026-01-07 13:02:58.176 | Added 3 Time and Sales records to Intraday data file for NQH6.CME after download.
2026-01-07 13:02:58.176 | HD Request # 1 | Completion time: 2s.
2026-01-07 13:02:58.176 | HD Request # 1 | Intraday data download complete for NQH6.CME. Unique request ID: 1
2026-01-07 13:02:58.176 | Removing historical data download ID 1.
2026-01-07 13:02:58.176 | Real-time Intraday chart data file updates started for NQH6.CME
2026-01-07 13:02:58.176 | Intraday chart data file opened for NQH6.CME
2026-01-07 13:02:58.176 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2026-01-07 13:02:58.176 | Triggering next historical data download in queue.
2026-01-07 13:02:58.176 | Delaying start of download for ESH6.CME.
2026-01-07 13:02:58.181 | NQH6.CME/MNQH6.CME [C] 1 Min #9 | Download is complete for all contract months in chart. Proceeding with data load.
2026-01-07 13:02:58.185 | NQH6.CME/MNQH6.CME [C] 1 Min #9 | Reloading chart. | Number times message added: 1
2026-01-07 13:02:58.196 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=100
2026-01-07 13:02:58.256 | Socket (3) | Socket gracefully closed by remote side.
2026-01-07 13:02:58.256 | Socket (3) | Closed.
2026-01-07 13:02:58.286 | Denali Data Feed | Market Depth data has been rejected for symbol: NQH6.CME. Not authorized for market depth.
2026-01-07 13:02:58.354 | NQH6.CME [C] 15 Min #5 | Download is complete for all contract months in chart. Proceeding with data load.
2026-01-07 13:02:58.354 | NQH6.CME [C] 15 Min #5 | Reloading chart.
2026-01-07 13:02:58.365 | NQH6.CME [C] 5 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2026-01-07 13:02:58.365 | NQH6.CME [C] 5 Min #7 | Reloading chart.
2026-01-07 13:02:58.765 | NQH6.CME [C] 15 Min #5 | Reloading chart.
2026-01-07 13:02:58.781 | NQH6.CME [C] 5 Min #7 | Reloading chart.
2026-01-07 13:02:58.850 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 2026-01-06 15:00:00
2026-01-07 13:02:59.014 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Chart data loading complete.
2026-01-07 13:03:01.572 | NQH6.CME [C][M] 15 Min #5 | Chart data loading complete.
2026-01-07 13:03:02.307 | HD Request # 2 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme
2026-01-07 13:03:02.307 | HD Request # 2 | Download start date-time: 2026-01-07 10:08:47.000000. File last date-time: 2026-01-07 10:08:47.080002
2026-01-07 13:03:02.308 | HD Request # 2 | Using server: ds28.sierracharts.com port 10149
2026-01-07 13:03:02.312 | Socket (3) | Creating socket.
2026-01-07 13:03:02.312 | Socket (3) | New receive buffer size: 0
2026-01-07 13:03:02.313 | Socket (3) | Connecting to IP: 67.214.125.5.
2026-01-07 13:03:02.487 | HD Request # 2 | Setting DTC encoding to Binary VLS
2026-01-07 13:03:02.487 | HD Request # 2 | Sending historical data logon request message.
2026-01-07 13:03:02.602 | HD Request # 2 | Requesting Intraday data. Start date-time: 2026-01-07 10:08:47. Record interval: 0. Symbol: ESH26
2026-01-07 13:03:02.686 | HD Request # 2 | Decompressing data.
2026-01-07 13:03:02.788 | HD Request # 2 | Receiving Intraday data for ESH6.CME starting at 2026-01-07 10:08:47.065000
2026-01-07 13:03:02.971 | HD Request # 2 | Timestamp of first Intraday data file record written: 2026-01-07 10:08:50.043000.
2026-01-07 13:03:03.191 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=100
2026-01-07 13:03:03.287 | Opened cached Intraday file: C:\SierraChart\Data\NQH6.CME.scid. Thread ID: 21768
2026-01-07 13:03:03.352 | Denali Data Feed | Market Depth data has been rejected for symbol: ESH6.CME. Not authorized for market depth.
2026-01-07 13:03:03.623 | NQH6.CME [C][M] 5 Min #7 | Chart data loading complete.
2026-01-07 13:03:03.815 | Socket (3) | CloseSocket call.
2026-01-07 13:03:03.815 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-01-07 13:03:03.815 | Historical data download thread signaled to stop.
2026-01-07 13:03:03.816 | HD Request # 2 | Received 307599 Intraday data records from 2026-01-07 10:08:47.065000 to 2026-01-07 13:03:02.270000 (2.9 hours. Delay: 1.5 seconds) and wrote 307566 records for ESH6.CME
2026-01-07 13:03:03.825 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2026-01-07 21:03:02.270000
2026-01-07 13:03:03.825 | Added 65 Time and Sales records to Intraday data file for ESH6.CME after download.
2026-01-07 13:03:03.825 | HD Request # 2 | Completion time: 1s.
2026-01-07 13:03:03.825 | HD Request # 2 | Intraday data download complete for ESH6.CME. Unique request ID: 2
2026-01-07 13:03:03.825 | Removing historical data download ID 2.
2026-01-07 13:03:03.825 | Real-time Intraday chart data file updates started for ESH6.CME
2026-01-07 13:03:03.825 | Intraday chart data file opened for ESH6.CME
2026-01-07 13:03:03.825 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2026-01-07 13:03:03.825 | No download requests in the queue to start downloads for.
2026-01-07 13:03:03.905 | Socket (3) | Socket gracefully closed by remote side.
2026-01-07 13:03:03.905 | Socket (3) | Closed.
2026-01-07 13:03:04.094 | ESH6.CME [C] #4 | Download is complete for all contract months in chart. Proceeding with data load.
2026-01-07 13:03:04.094 | ESH6.CME [C] #4 | Reloading chart. | Number times message added: 1
2026-01-07 13:03:08.300 | Opened cached Intraday file: C:\SierraChart\Data\ESH6.CME.scid. Thread ID: 21768
2026-01-07 13:03:12.786 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2.
2026-01-07 13:03:12.786 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | New receive buffer size: 0
2026-01-07 13:03:12.786 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Connecting to IP: 38.79.0.89.
2026-01-07 13:03:13.489 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side. | Number times message added: 1
2026-01-07 13:03:13.489 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 110576
2026-01-07 13:03:13.490 | Rithmic Direct - DTC | Processed connection points. Count: 474
2026-01-07 13:03:13.490 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | CloseSocket call.
2026-01-07 13:03:13.490 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-01-07 13:03:13.490 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Closed.
2026-01-07 13:03:18.213 | ESH6.CME/MESH6.CME[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-01-07 13:03:18.216 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-01-07 13:03:33.138 | ESH6.CME [C][M] #4 | Chart data loading complete.
2026-01-07 13:06:49.033 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 2026-01-06 15:00:00
2026-01-07 13:06:49.238 | ESH6.CME/MESH6.CME[M] #2 | StartDateTimeForLoadingOrderFills: 2024-12-31 00:00:00
2026-01-07 13:10:41.922 | File >> Disconnect selected.
2026-01-07 13:10:41.925 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-01-07 13:10:41.926 | DTC Client socket (1) | CloseSocket call.
2026-01-07 13:10:41.926 | DTC Client socket (1) | Max send buffers used during socket life: 3
2026-01-07 13:10:41.926 | DTC Client socket (1) | Max send buffer size during socket life: 406
2026-01-07 13:10:41.926 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:10:41.926 | Denali Data Feed | Waiting for socket receive thread to end
2026-01-07 13:10:41.926 | DTC Client socket (2) | CloseSocket call.
2026-01-07 13:10:41.926 | DTC Client socket (2) | Max send buffers used during socket life: 3
2026-01-07 13:10:41.926 | DTC Client socket (2) | Max send buffer size during socket life: 206
2026-01-07 13:10:41.926 | Denali Data Feed | Disconnected from the server.
2026-01-07 13:10:41.926 | Rithmic Direct - DTC | Disconnected.
2026-01-07 13:10:41.926 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-01-07 13:10:42.004 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-01-07 13:10:42.004 | DTC Client socket (1) | Closed.
2026-01-07 13:10:42.111 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-01-07 13:10:42.111 | DTC Client socket (2) | Closed.
2026-01-07 13:10:44.134 |
2026-01-07 13:10:44.134 | Rithmic Direct - DTC | Using server connection: LegendsTrading-Chicago Area-Aggregated
2026-01-07 13:10:44.134 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50581
2026-01-07 13:10:44.134 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50581
2026-01-07 13:10:44.268 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-01-07 13:10:44.268 | DTC Client socket (1) | New receive buffer size: 0
2026-01-07 13:10:44.268 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2026-01-07 13:10:44.350 | Rithmic Direct - DTC | Network connection to server complete.
2026-01-07 13:10:44.350 | Rithmic Direct - DTC | Starting socket receive thread.
2026-01-07 13:10:44.350 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-01-07 13:10:44.350 | Rithmic Direct - DTC | Sending logon request message.
2026-01-07 13:10:44.595 | Rithmic Direct - DTC | Received logon response.
2026-01-07 13:10:44.595 | Rithmic Direct - DTC | Server Name: .
2026-01-07 13:10:44.595 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:10:44.595 | Rithmic Direct - DTC | Logon error received from server: permission denied
2026-01-07 13:10:44.595 | Rithmic Direct - DTC | Failed connections: 1
2026-01-07 13:10:44.595 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-01-07 13:10:44.595 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-01-07 13:10:44.620 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-01-07 13:10:44.620 | DTC Client socket (1) | CloseSocket call.
2026-01-07 13:10:44.620 | Rithmic Direct - DTC | Disconnected.
2026-01-07 13:10:44.620 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-01-07 13:10:44.620 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:10:44.699 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-01-07 13:10:44.699 | DTC Client socket (1) | Closed.
2026-01-07 13:10:48.636 |
2026-01-07 13:10:48.636 | Rithmic Direct - DTC | Using server connection: LegendsTrading-Chicago Area-Aggregated
2026-01-07 13:10:48.636 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50581
2026-01-07 13:10:48.636 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50581
2026-01-07 13:10:48.636 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-01-07 13:10:48.637 | DTC Client socket (1) | New receive buffer size: 0
2026-01-07 13:10:48.637 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2026-01-07 13:10:48.714 | Rithmic Direct - DTC | Network connection to server complete.
2026-01-07 13:10:48.714 | Rithmic Direct - DTC | Starting socket receive thread.
2026-01-07 13:10:48.715 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-01-07 13:10:48.715 | Rithmic Direct - DTC | Sending logon request message.
2026-01-07 13:10:48.968 | Rithmic Direct - DTC | Received logon response.
2026-01-07 13:10:48.968 | Rithmic Direct - DTC | Server Name: .
2026-01-07 13:10:48.968 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:10:48.968 | Rithmic Direct - DTC | Logon error received from server: permission denied
2026-01-07 13:10:48.968 | Rithmic Direct - DTC | Failed connections: 2
2026-01-07 13:10:48.968 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-01-07 13:10:48.968 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-01-07 13:10:49.001 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-01-07 13:10:49.001 | DTC Client socket (1) | CloseSocket call.
2026-01-07 13:10:49.001 | Rithmic Direct - DTC | Disconnected.
2026-01-07 13:10:49.001 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-01-07 13:10:49.001 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:10:49.080 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-01-07 13:10:49.080 | DTC Client socket (1) | Closed.
2026-01-07 13:10:52.996 |
2026-01-07 13:10:52.996 | Rithmic Direct - DTC | Using server connection: LegendsTrading-Chicago Area-Aggregated
2026-01-07 13:10:52.996 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50581
2026-01-07 13:10:52.996 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50581
2026-01-07 13:10:52.998 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-01-07 13:10:52.998 | DTC Client socket (1) | New receive buffer size: 0
2026-01-07 13:10:52.998 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2026-01-07 13:10:53.076 | Rithmic Direct - DTC | Network connection to server complete.
2026-01-07 13:10:53.076 | Rithmic Direct - DTC | Starting socket receive thread.
2026-01-07 13:10:53.076 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-01-07 13:10:53.076 | Rithmic Direct - DTC | Sending logon request message.
2026-01-07 13:10:53.237 | File >> Disconnect selected.
2026-01-07 13:10:53.237 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-01-07 13:10:53.238 | DTC Client socket (1) | CloseSocket call.
2026-01-07 13:10:53.238 | Rithmic Direct - DTC | Disconnected.
2026-01-07 13:10:53.238 | DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0
2026-01-07 13:10:53.242 | DTC Client socket (1) | Write has completed. Shutdown being performed.
2026-01-07 13:10:53.242 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:10:53.319 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-01-07 13:10:53.319 | DTC Client socket (1) | Closed.
2026-01-07 13:11:14.316 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2.
2026-01-07 13:11:14.316 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | New receive buffer size: 0
2026-01-07 13:11:14.316 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Connecting to IP: 216.66.0.130.
2026-01-07 13:11:14.889 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 110576
2026-01-07 13:11:14.890 | Rithmic Direct - DTC | Processed connection points. Count: 474
2026-01-07 13:11:15.137 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | CloseSocket call.
2026-01-07 13:11:15.137 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:11:15.217 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Socket gracefully closed by remote side.
2026-01-07 13:11:15.217 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Closed.
2026-01-07 13:11:56.188 |
2026-01-07 13:11:56.188 | Rithmic Direct - DTC | Using server connection: LegendsTrading-Chicago Area-Aggregated
2026-01-07 13:11:56.188 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50581
2026-01-07 13:11:56.188 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50581
2026-01-07 13:11:56.189 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-01-07 13:11:56.189 | DTC Client socket (1) | New receive buffer size: 0
2026-01-07 13:11:56.189 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2026-01-07 13:11:56.270 | Rithmic Direct - DTC | Network connection to server complete.
2026-01-07 13:11:56.270 | Rithmic Direct - DTC | Starting socket receive thread.
2026-01-07 13:11:56.270 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-01-07 13:11:56.270 | Rithmic Direct - DTC | Sending logon request message.
2026-01-07 13:11:56.524 | Rithmic Direct - DTC | Received logon response.
2026-01-07 13:11:56.524 | Rithmic Direct - DTC | Server Name: .
2026-01-07 13:11:56.524 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:11:56.524 | Rithmic Direct - DTC | Logon error received from server: permission denied
2026-01-07 13:11:56.524 | Rithmic Direct - DTC | Failed connections: 3
2026-01-07 13:11:56.524 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-01-07 13:11:56.524 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-01-07 13:11:56.564 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-01-07 13:11:56.564 | DTC Client socket (1) | CloseSocket call.
2026-01-07 13:11:56.564 | Rithmic Direct - DTC | Disconnected.
2026-01-07 13:11:56.564 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-01-07 13:11:56.564 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:11:56.648 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-01-07 13:11:56.648 | DTC Client socket (1) | Closed.
2026-01-07 13:12:00.549 |
2026-01-07 13:12:00.549 | Rithmic Direct - DTC | Using server connection: LegendsTrading-Chicago Area-Aggregated
2026-01-07 13:12:00.549 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50581
2026-01-07 13:12:00.549 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50581
2026-01-07 13:12:00.550 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-01-07 13:12:00.550 | DTC Client socket (1) | New receive buffer size: 0
2026-01-07 13:12:00.550 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2026-01-07 13:12:00.631 | Rithmic Direct - DTC | Network connection to server complete.
2026-01-07 13:12:00.631 | Rithmic Direct - DTC | Starting socket receive thread.
2026-01-07 13:12:00.631 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-01-07 13:12:00.631 | Rithmic Direct - DTC | Sending logon request message.
2026-01-07 13:12:00.876 | Rithmic Direct - DTC | Received logon response.
2026-01-07 13:12:00.876 | Rithmic Direct - DTC | Server Name: .
2026-01-07 13:12:00.876 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:12:00.876 | Rithmic Direct - DTC | Logon error received from server: permission denied
2026-01-07 13:12:00.876 | Rithmic Direct - DTC | Failed connections: 4
2026-01-07 13:12:00.876 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-01-07 13:12:00.876 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-01-07 13:12:00.898 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-01-07 13:12:00.899 | DTC Client socket (1) | CloseSocket call.
2026-01-07 13:12:00.899 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:12:00.899 | Rithmic Direct - DTC | Disconnected.
2026-01-07 13:12:00.899 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-01-07 13:12:00.979 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-01-07 13:12:00.979 | DTC Client socket (1) | Closed.
2026-01-07 13:12:04.342 | File >> Disconnect selected.
2026-01-07 13:12:04.342 | DTC Client socket (0) | CloseSocket call.
2026-01-07 13:12:04.342 | Rithmic Direct - DTC | Disconnected.
2026-01-07 13:12:20.569 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.2.
2026-01-07 13:12:20.569 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (1) | New receive buffer size: 0
2026-01-07 13:12:20.569 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (1) | Connecting to IP: 216.66.0.130.
2026-01-07 13:12:21.150 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 110576
2026-01-07 13:12:21.151 | Rithmic Direct - DTC | Processed connection points. Count: 474
2026-01-07 13:12:21.349 |
2026-01-07 13:12:21.349 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Aggregated
2026-01-07 13:12:21.349 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569
2026-01-07 13:12:21.349 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569
2026-01-07 13:12:21.349 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-01-07 13:12:21.350 | DTC Client socket (2) | New receive buffer size: 0
2026-01-07 13:12:21.350 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2026-01-07 13:12:21.405 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (1) | CloseSocket call.
2026-01-07 13:12:21.405 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:12:21.453 | Rithmic Direct - DTC | Network connection to server complete.
2026-01-07 13:12:21.453 | Rithmic Direct - DTC | Starting socket receive thread.
2026-01-07 13:12:21.454 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-01-07 13:12:21.454 | Rithmic Direct - DTC | Sending logon request message.
2026-01-07 13:12:21.489 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (1) | Socket gracefully closed by remote side.
2026-01-07 13:12:21.489 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (1) | Closed.
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | Received logon response.
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | Server Name: .
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | Successfully connected.
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | Trading is supported.
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | Order cancel and replace is supported.
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | OCO Orders supported.
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2026-01-07 13:12:21.709 | Rithmic Direct - DTC | Connection to server complete.
2026-01-07 13:12:21.709 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-01-07 13:12:21.714 | Mapping ESH6.CME to ESH26. Service code: cme
2026-01-07 13:12:21.714 | Using symbol data fast lookup vector
2026-01-07 13:12:21.714 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 1 Service code: cme
2026-01-07 13:12:21.714 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 10048
2026-01-07 13:12:21.714 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 1
2026-01-07 13:12:21.714 | Added historical Intraday data request for ESH6.CME to the queue.
2026-01-07 13:12:21.714 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'.
2026-01-07 13:12:21.714 | Triggering next historical data download in queue.
2026-01-07 13:12:21.714 | DTC Client socket (1) | Creating socket.
2026-01-07 13:12:21.714 | DTC Client socket (1) | New receive buffer size: 0
2026-01-07 13:12:21.714 | DTC Client socket (1) | Connecting to IP: 69.39.70.248.
2026-01-07 13:12:21.722 | Delaying start of download for ESH6.CME.
2026-01-07 13:12:21.724 | Mapping MESH6.CME to MESH26. Service code: cme
2026-01-07 13:12:21.724 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 2 Service code: cme
2026-01-07 13:12:21.724 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 2
2026-01-07 13:12:21.726 | Mapping NQH6.CME to NQH26. Service code: cme
2026-01-07 13:12:21.726 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 3 Service code: cme
2026-01-07 13:12:21.726 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 3
2026-01-07 13:12:21.726 | Mapping MNQH6.CME to MNQH26. Service code: cme
2026-01-07 13:12:21.726 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 4 Service code: cme
2026-01-07 13:12:21.726 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 4
2026-01-07 13:12:21.726 | Added historical Intraday data request for NQH6.CME to the queue.
2026-01-07 13:12:21.726 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'.
2026-01-07 13:12:21.726 | Triggering next historical data download in queue.
2026-01-07 13:12:21.803 | Denali Data Feed | Network connection to server complete.
2026-01-07 13:12:21.803 | Denali Data Feed | Starting socket receive thread.
2026-01-07 13:12:21.803 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-01-07 13:12:21.925 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-01-07 13:12:21.925 | Denali Data Feed | Sending logon request message.
2026-01-07 13:12:22.454 | Denali Data Feed | Received logon response.
2026-01-07 13:12:22.454 | Denali Data Feed | Server Name: SC Realtime Server.
2026-01-07 13:12:22.454 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:12:22.454 | Denali Data Feed | Successfully connected.
2026-01-07 13:12:22.454 | Denali Data Feed | Trading is not supported.
2026-01-07 13:12:22.454 | Denali Data Feed | MarketDepthIsSupported: 1
2026-01-07 13:12:22.454 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26
2026-01-07 13:12:22.454 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26
2026-01-07 13:12:22.454 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26
2026-01-07 13:12:22.454 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26
2026-01-07 13:12:22.643 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878
2026-01-07 13:12:22.643 | Denali Data Feed | Received security definition for symbol ESH6.CME
2026-01-07 13:12:22.643 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800
2026-01-07 13:12:22.643 | Denali Data Feed | Received security definition for symbol MESH6.CME
2026-01-07 13:12:22.643 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946
2026-01-07 13:12:22.643 | Denali Data Feed | Received security definition for symbol MNQH6.CME
2026-01-07 13:12:22.643 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475
2026-01-07 13:12:22.643 | Denali Data Feed | Received security definition for symbol NQH6.CME
2026-01-07 13:12:26.712 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=100
2026-01-07 13:12:26.712 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=100
2026-01-07 13:12:26.892 | Denali Data Feed | Market Depth data has been rejected for symbol: ESH6.CME. Not authorized for market depth.
2026-01-07 13:12:26.892 | Denali Data Feed | Market Depth data has been rejected for symbol: NQH6.CME. Not authorized for market depth.
2026-01-07 13:12:27.464 | HD Request # 3 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme
2026-01-07 13:12:27.464 | HD Request # 3 | Download start date-time: 2026-01-07 13:10:41.000000. File last date-time: 2026-01-07 13:10:41.277000
2026-01-07 13:12:27.464 | HD Request # 3 | Using server: ds26.sierracharts.com port 10150
2026-01-07 13:12:27.465 | Socket (3) | Creating socket.
2026-01-07 13:12:27.465 | Socket (3) | New receive buffer size: 0
2026-01-07 13:12:27.465 | Socket (3) | Connecting to IP: 64.152.155.17.
2026-01-07 13:12:27.644 | HD Request # 3 | Setting DTC encoding to Binary VLS
2026-01-07 13:12:27.644 | HD Request # 3 | Sending historical data logon request message.
2026-01-07 13:12:27.757 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-01-07 13:10:41. Record interval: 0. Symbol: ESH26
2026-01-07 13:12:27.842 | HD Request # 3 | Decompressing data.
2026-01-07 13:12:27.932 | HD Request # 3 | Receiving Intraday data for ESH6.CME starting at 2026-01-07 13:10:41.277000
2026-01-07 13:12:27.937 | Socket (3) | CloseSocket call.
2026-01-07 13:12:27.937 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-01-07 13:12:27.938 | Historical data download thread signaled to stop.
2026-01-07 13:12:27.938 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-01-07 13:10:42.715000.
2026-01-07 13:12:27.938 | HD Request # 3 | Received 946 Intraday data records from 2026-01-07 13:10:41.277000 to 2026-01-07 13:12:26.246000 (105.0 seconds. Delay: 1.7 seconds) and wrote 945 records for ESH6.CME
2026-01-07 13:12:27.945 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-01-07 21:12:26.246000
2026-01-07 13:12:27.945 | HD Request # 3 | Completion time: 0s.
2026-01-07 13:12:27.945 | HD Request # 3 | Intraday data download complete for ESH6.CME. Unique request ID: 3
2026-01-07 13:12:27.945 | Removing historical data download ID 3.
2026-01-07 13:12:27.945 | Real-time Intraday chart data file updates started for ESH6.CME
2026-01-07 13:12:27.945 | Intraday chart data file opened for ESH6.CME
2026-01-07 13:12:27.945 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2026-01-07 13:12:27.945 | Triggering next historical data download in queue.
2026-01-07 13:12:27.945 | HD Request # 4 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme
2026-01-07 13:12:27.946 | HD Request # 4 | Download start date-time: 2026-01-07 13:10:41.000000. File last date-time: 2026-01-07 13:10:41.954000
2026-01-07 13:12:27.946 | HD Request # 4 | Using server: ds32.sierracharts.com port 10149
2026-01-07 13:12:27.946 | Socket (4) | Creating socket.
2026-01-07 13:12:27.946 | Socket (4) | New receive buffer size: 0
2026-01-07 13:12:27.946 | Socket (4) | Connecting to IP: 69.39.70.248.
2026-01-07 13:12:28.021 | Socket (3) | Socket gracefully closed by remote side.
2026-01-07 13:12:28.021 | Socket (3) | Closed.
2026-01-07 13:12:28.124 | HD Request # 4 | Setting DTC encoding to Binary VLS
2026-01-07 13:12:28.124 | HD Request # 4 | Sending historical data logon request message.
2026-01-07 13:12:28.240 | HD Request # 4 | Requesting Intraday data. Start date-time: 2026-01-07 13:10:41. Record interval: 0. Symbol: NQH26
2026-01-07 13:12:28.323 | HD Request # 4 | Decompressing data.
2026-01-07 13:12:28.409 | HD Request # 4 | Receiving Intraday data for NQH6.CME starting at 2026-01-07 13:10:41.952000
2026-01-07 13:12:28.409 | Socket (4) | CloseSocket call.
2026-01-07 13:12:28.409 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-01-07 13:12:28.417 | Historical data download thread signaled to stop.
2026-01-07 13:12:28.417 | HD Request # 4 | Timestamp of first Intraday data file record written: 2026-01-07 13:10:42.715000.
2026-01-07 13:12:28.417 | HD Request # 4 | Received 519 Intraday data records from 2026-01-07 13:10:41.952000 to 2026-01-07 13:12:27.922001 (106.0 seconds. Delay: 0.5 seconds) and wrote 514 records for NQH6.CME
2026-01-07 13:12:28.424 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2026-01-07 21:12:27.922001
2026-01-07 13:12:28.424 | Added 2 Time and Sales records to Intraday data file for NQH6.CME after download.
2026-01-07 13:12:28.424 | HD Request # 4 | Completion time: 1s.
2026-01-07 13:12:28.424 | HD Request # 4 | Intraday data download complete for NQH6.CME. Unique request ID: 4
2026-01-07 13:12:28.424 | Removing historical data download ID 4.
2026-01-07 13:12:28.424 | Real-time Intraday chart data file updates started for NQH6.CME
2026-01-07 13:12:28.424 | Intraday chart data file opened for NQH6.CME
2026-01-07 13:12:28.424 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2026-01-07 13:12:28.424 | No download requests in the queue to start downloads for.
2026-01-07 13:12:28.499 | Socket (4) | Socket gracefully closed by remote side.
2026-01-07 13:12:28.499 | Socket (4) | Closed.
2026-01-07 13:12:29.201 | Opened cached Intraday file: C:\SierraChart\Data\ESH6.CME.scid. Thread ID: 21768
2026-01-07 13:12:29.203 | Opened cached Intraday file: C:\SierraChart\Data\NQH6.CME.scid. Thread ID: 21768
2026-01-07 13:12:41.366 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (3) | Creating socket. Using TLS 1.2.
2026-01-07 13:12:41.366 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (3) | New receive buffer size: 0
2026-01-07 13:12:41.366 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (3) | Connecting to IP: 216.66.0.130.
2026-01-07 13:12:41.961 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 110576
2026-01-07 13:12:41.961 | Rithmic Direct - DTC | Processed connection points. Count: 474
2026-01-07 13:12:42.214 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (3) | CloseSocket call.
2026-01-07 13:12:42.214 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (3) | Shutdown started. Waiting for graceful close.
2026-01-07 13:12:42.296 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (3) | Socket gracefully closed by remote side.
2026-01-07 13:12:42.296 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (3) | Closed.
2026-01-07 13:14:11.184 | File >> Disconnect selected.
2026-01-07 13:14:11.187 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-01-07 13:14:11.187 | DTC Client socket (2) | CloseSocket call.
2026-01-07 13:14:11.187 | DTC Client socket (2) | Max send buffers used during socket life: 3
2026-01-07 13:14:11.187 | DTC Client socket (2) | Max send buffer size during socket life: 406
2026-01-07 13:14:11.188 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-01-07 13:14:11.188 | Denali Data Feed | Waiting for socket receive thread to end
2026-01-07 13:14:11.188 | DTC Client socket (1) | CloseSocket call.
2026-01-07 13:14:11.188 | Denali Data Feed | Disconnected from the server.
2026-01-07 13:14:11.188 | Rithmic Direct - DTC | Disconnected.
2026-01-07 13:14:11.188 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-01-07 13:14:11.266 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-01-07 13:14:11.266 | DTC Client socket (2) | Closed.
2026-01-07 13:14:11.403 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-01-07 13:14:11.403 | DTC Client socket (1) | Closed.
2026-01-07 13:14:13.420 |
2026-01-07 13:14:13.420 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated
2026-01-07 13:14:13.420 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569
2026-01-07 13:14:13.420 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569
2026-01-07 13:14:13.425 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-01-07 13:14:13.425 | DTC Client socket (1) | New receive buffer size: 0
2026-01-07 13:14:13.425 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2026-01-07 13:14:13.503 | Rithmic Direct - DTC | Network connection to server complete.
2026-01-07 13:14:13.503 | Rithmic Direct - DTC | Starting socket receive thread.
2026-01-07 13:14:13.503 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-01-07 13:14:13.503 | Rithmic Direct - DTC | Sending logon request message.
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | Received logon response.
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | Server Name: .
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | Successfully connected.
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | Trading is supported.
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | Order cancel and replace is supported.
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | OCO Orders supported.
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2026-01-07 13:14:13.749 | Rithmic Direct - DTC | Connection to server complete.
2026-01-07 13:14:13.753 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-01-07 13:14:13.757 | Mapping ESH6.CME to ESH26. Service code: cme
2026-01-07 13:14:13.757 | Using symbol data fast lookup vector
2026-01-07 13:14:13.757 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 1 Service code: cme
2026-01-07 13:14:13.757 | Denali Data Feed | Connecting to the server ds27-2.sierracharts.com. Port 443
2026-01-07 13:14:13.757 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 1
2026-01-07 13:14:13.757 | Mapping MESH6.CME to MESH26. Service code: cme
2026-01-07 13:14:13.757 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 2 Service code: cme
2026-01-07 13:14:13.757 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 2
2026-01-07 13:14:13.757 | Added historical Intraday data request for ESH6.CME to the queue.
2026-01-07 13:14:13.757 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'.
2026-01-07 13:14:13.757 | Triggering next historical data download in queue.
2026-01-07 13:14:13.758 | Delaying start of download for ESH6.CME.
2026-01-07 13:14:13.764 | Mapping NQH6.CME to NQH26. Service code: cme
2026-01-07 13:14:13.764 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 3 Service code: cme
2026-01-07 13:14:13.764 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 3
2026-01-07 13:14:13.764 | Mapping MNQH6.CME to MNQH26. Service code: cme
2026-01-07 13:14:13.764 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 4 Service code: cme
2026-01-07 13:14:13.764 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 4
2026-01-07 13:14:13.764 | Added historical Intraday data request for NQH6.CME to the queue.
2026-01-07 13:14:13.764 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'.
2026-01-07 13:14:13.764 | Triggering next historical data download in queue.
2026-01-07 13:14:13.855 | DTC Client socket (2) | Creating socket.
2026-01-07 13:14:13.855 | DTC Client socket (2) | New receive buffer size: 0
2026-01-07 13:14:13.855 | DTC Client socket (2) | Connecting to IP: 216.200.108.155.
2026-01-07 13:14:13.919 | Denali Data Feed | Network connection to server complete.
2026-01-07 13:14:13.919 | Denali Data Feed | Starting socket receive thread.
2026-01-07 13:14:13.919 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-01-07 13:14:13.996 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-01-07 13:14:13.996 | Denali Data Feed | Sending logon request message.
2026-01-07 13:14:14.529 | Denali Data Feed | Received logon response.
2026-01-07 13:14:14.529 | Denali Data Feed | Server Name: SC Realtime Server.
2026-01-07 13:14:14.529 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-01-07 13:14:14.529 | Denali Data Feed | Successfully connected.
2026-01-07 13:14:14.529 | Denali Data Feed | Trading is not supported.
2026-01-07 13:14:14.529 | Denali Data Feed | MarketDepthIsSupported: 1
2026-01-07 13:14:14.529 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26
2026-01-07 13:14:14.530 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26
2026-01-07 13:14:14.530 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26
2026-01-07 13:14:14.530 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26
2026-01-07 13:14:14.683 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878
2026-01-07 13:14:14.683 | Denali Data Feed | Received security definition for symbol ESH6.CME
2026-01-07 13:14:14.683 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800
2026-01-07 13:14:14.683 | Denali Data Feed | Received security definition for symbol MESH6.CME
2026-01-07 13:14:14.683 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946
2026-01-07 13:14:14.683 | Denali Data Feed | Received security definition for symbol MNQH6.CME
2026-01-07 13:14:14.683 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475
2026-01-07 13:14:14.683 | Denali Data Feed | Received security definition for symbol NQH6.CME
2026-01-07 13:14:18.743 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=100
2026-01-07 13:14:18.743 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=100
2026-01-07 13:14:18.851 | Denali Data Feed | Market Depth data has been rejected for symbol: ESH6.CME. Not authorized for market depth.
2026-01-07 13:14:18.851 | Denali Data Feed | Market Depth data has been rejected for symbol: NQH6.CME. Not authorized for market depth.
2026-01-07 13:14:19.495 | HD Request # 5 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme
2026-01-07 13:14:19.496 | HD Request # 5 | Download start date-time: 2026-01-07 13:14:11.000000. File last date-time: 2026-01-07 13:14:11.709000
2026-01-07 13:14:19.496 | HD Request # 5 | Using server: ds28.sierracharts.com port 10150
2026-01-07 13:14:19.496 | Socket (3) | Creating socket.
2026-01-07 13:14:19.496 | Socket (3) | New receive buffer size: 0
2026-01-07 13:14:19.496 | Socket (3) | Connecting to IP: 67.214.125.5.
2026-01-07 13:14:19.677 | HD Request # 5 | Setting DTC encoding to Binary VLS
2026-01-07 13:14:19.677 | HD Request # 5 | Sending historical data logon request message.
2026-01-07 13:14:19.801 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-01-07 13:14:11. Record interval: 0. Symbol: ESH26
2026-01-07 13:14:19.885 | HD Request # 5 | Decompressing data.
2026-01-07 13:14:19.969 | HD Request # 5 | Receiving Intraday data for ESH6.CME starting at 2026-01-07 13:14:11.410000
2026-01-07 13:14:19.970 | Socket (3) | CloseSocket call.
2026-01-07 13:14:19.970 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-01-07 13:14:19.970 | Historical data download thread signaled to stop.
2026-01-07 13:14:19.970 | HD Request # 5 | Timestamp of first Intraday data file record written: 2026-01-07 13:14:12.427000.
2026-01-07 13:14:19.971 | HD Request # 5 | Received 7 Intraday data records from 2026-01-07 13:14:11.410000 to 2026-01-07 13:14:15.570000 (4.2 seconds. Delay: 4.4 seconds) and wrote 3 records for ESH6.CME
2026-01-07 13:14:19.986 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2026-01-07 21:14:15.570000
2026-01-07 13:14:19.986 | Added 10 Time and Sales records to Intraday data file for ESH6.CME after download.
2026-01-07 13:14:19.987 | HD Request # 5 | Completion time: 0s.
2026-01-07 13:14:19.987 | HD Request # 5 | Intraday data download complete for ESH6.CME. Unique request ID: 5
2026-01-07 13:14:19.987 | Removing historical data download ID 5.
2026-01-07 13:14:19.987 | Real-time Intraday chart data file updates started for ESH6.CME
2026-01-07 13:14:19.987 | Intraday chart data file opened for ESH6.CME
2026-01-07 13:14:19.987 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2026-01-07 13:14:19.987 | Triggering next historical data download in queue.
2026-01-07 13:14:19.987 | HD Request # 6 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme
2026-01-07 13:14:19.987 | HD Request # 6 | Download start date-time: 2026-01-07 13:14:11.000000. File last date-time: 2026-01-07 13:14:11.410000
2026-01-07 13:14:19.987 | HD Request # 6 | Using server: ds26.sierracharts.com port 10149
2026-01-07 13:14:19.988 | Socket (4) | Creating socket.
2026-01-07 13:14:19.988 | Socket (4) | New receive buffer size: 0
2026-01-07 13:14:19.988 | Socket (4) | Connecting to IP: 64.152.155.17.
2026-01-07 13:14:20.055 | Socket (3) | Socket gracefully closed by remote side.
2026-01-07 13:14:20.055 | Socket (3) | Closed.
2026-01-07 13:14:20.164 | HD Request # 6 | Setting DTC encoding to Binary VLS
2026-01-07 13:14:20.164 | HD Request # 6 | Sending historical data logon request message.
2026-01-07 13:14:20.288 | HD Request # 6 | Requesting Intraday data. Start date-time: 2026-01-07 13:14:11. Record interval: 0. Symbol: NQH26
2026-01-07 13:14:20.373 | HD Request # 6 | Decompressing data.
2026-01-07 13:14:20.459 | HD Request # 6 | Receiving Intraday data for NQH6.CME starting at 2026-01-07 13:14:11.082000
2026-01-07 13:14:20.459 | Socket (4) | CloseSocket call.
2026-01-07 13:14:20.460 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-01-07 13:14:20.460 | Historical data download thread signaled to stop.
2026-01-07 13:14:20.460 | HD Request # 6 | Timestamp of first Intraday data file record written: 2026-01-07 13:14:12.321000.
2026-01-07 13:14:20.460 | HD Request # 6 | Received 18 Intraday data records from 2026-01-07 13:14:11.082000 to 2026-01-07 13:14:18.498003 (7.4 seconds. Delay: 2.0 seconds) and wrote 11 records for NQH6.CME
2026-01-07 13:14:20.467 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2026-01-07 21:14:18.498003
2026-01-07 13:14:20.467 | Added 11 Time and Sales records to Intraday data file for NQH6.CME after download.
2026-01-07 13:14:20.467 | HD Request # 6 | Completion time: 1s.
2026-01-07 13:14:20.467 | HD Request # 6 | Intraday data download complete for NQH6.CME. Unique request ID: 6
2026-01-07 13:14:20.467 | Removing historical data download ID 6.
2026-01-07 13:14:20.467 | Real-time Intraday chart data file updates started for NQH6.CME
2026-01-07 13:14:20.467 | Intraday chart data file opened for NQH6.CME
2026-01-07 13:14:20.467 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2026-01-07 13:14:20.467 | No download requests in the queue to start downloads for.
2026-01-07 13:14:20.544 | Socket (4) | Socket gracefully closed by remote side.
2026-01-07 13:14:20.544 | Socket (4) | Closed.
2026-01-07 13:14:24.364 | Opened cached Intraday file: C:\SierraChart\Data\NQH6.CME.scid. Thread ID: 21768
2026-01-07 13:14:29.367 | Opened cached Intraday file: C:\SierraChart\Data\ESH6.CME.scid. Thread ID: 21768
2026-01-07 13:14:33.421 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (3) | Creating socket. Using TLS 1.2.
2026-01-07 13:14:33.421 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (3) | New receive buffer size: 0
2026-01-07 13:14:33.421 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (3) | Connecting to IP: 216.66.0.130.
2026-01-07 13:14:33.994 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 110576
2026-01-07 13:14:33.995 | Rithmic Direct - DTC | Processed connection points. Count: 474
2026-01-07 13:14:34.255 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (3) | CloseSocket call.
2026-01-07 13:14:34.255 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (3) | Shutdown started. Waiting for graceful close.
2026-01-07 13:14:34.337 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (3) | Socket gracefully closed by remote side.
2026-01-07 13:14:34.337 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (3) | Closed.
2026-01-07 13:20:24.270 | NQH6.CME [C][M] #4 | Reloading chart.
2026-01-07 13:20:24.271 | Added historical Intraday data request for NQM5.CME to the queue.
2026-01-07 13:20:24.271 | Triggering next historical data download in queue.
2026-01-07 13:20:24.271 | NQH6.CME [C][M] #4 | Waiting for historical downloads to complete with the IDs: 7,
2026-01-07 13:20:24.289 | Mapping NQM5.CME to NQM25. Service code: cme
2026-01-07 13:20:24.289 | HD Request # 7 | Downloading Intraday chart data for NQM5.CME to the file NQM5.CME.scid. Service: cme
2026-01-07 13:20:24.289 | Enabling compression for file: C:\SierraChart\Data\NQM5.CME.scid
2026-01-07 13:20:24.289 | HD Request # 7 | Download start date-time: 2025-02-27 16:00:00.000000. File last date-time: 00:00:00.000000
2026-01-07 13:20:24.289 | HD Request # 7 | Using server: ds32.sierracharts.com port 10150
2026-01-07 13:20:24.289 | Socket (3) | Creating socket.
2026-01-07 13:20:24.289 | Socket (3) | New receive buffer size: 0
2026-01-07 13:20:24.289 | Socket (3) | Connecting to IP: 69.39.70.248.
2026-01-07 13:20:24.464 | HD Request # 7 | Setting DTC encoding to Binary VLS
2026-01-07 13:20:24.464 | HD Request # 7 | Sending historical data logon request message.
2026-01-07 13:20:24.580 | HD Request # 7 | Requesting Intraday data. Start date-time: 2025-02-27 16:00:00. Record interval: 0. Symbol: NQM25
2026-01-07 13:20:24.664 | HD Request # 7 | Decompressing data.
2026-01-07 13:20:24.870 | HD Request # 7 | Receiving Intraday data for NQM5.CME starting at 2025-02-27 16:00:00.993000
2026-01-07 13:20:25.114 | HD Request # 7 | Timestamp of first Intraday data file record written: 2025-02-27 16:00:00.993000.
2026-01-07 13:21:58.648 | Socket (3) | CloseSocket call.
2026-01-07 13:21:58.648 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-01-07 13:21:58.648 | Historical data download thread signaled to stop.
2026-01-07 13:21:58.648 | HD Request # 7 | Received 34367896 Intraday data records from 2025-02-27 16:00:00.993000 to 2025-06-20 06:29:46.685000 (112.6 days. Delay: 201.3 days) and wrote 34367896 records for NQM5.CME
2026-01-07 13:21:58.658 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2025-06-20 13:29:46.685000
2026-01-07 13:21:58.658 | HD Request # 7 | Completion time: 1m 34s.
2026-01-07 13:21:58.658 | HD Request # 7 | Intraday data download complete for NQM5.CME. Unique request ID: 7
2026-01-07 13:21:58.658 | Removing historical data download ID 7.
2026-01-07 13:21:58.658 | Real-time Intraday chart data file updates started for NQM5.CME
2026-01-07 13:21:58.658 | Intraday chart data file opened for NQM5.CME
2026-01-07 13:21:58.658 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2026-01-07 13:21:58.658 | No download requests in the queue to start downloads for.
2026-01-07 13:21:58.750 | Socket (3) | Socket gracefully closed by remote side.
2026-01-07 13:21:58.750 | Socket (3) | Closed.
2026-01-07 13:21:59.001 | NQH6.CME [C][M] #4 | Download is complete for all contract months in chart. Proceeding with data load.
2026-01-07 13:21:59.008 | NQH6.CME [C][M] #4 | Reloading chart. | Number times message added: 1
2026-01-07 13:22:13.858 | NQH6.CME [C][M] #4 | Chart data loading complete.
2026-01-07 13:26:46.593 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:26:46.593 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:26:51.678 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:26:51.678 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:27:20.575 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:27:20.575 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:27:50.866 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:27:50.866 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:28:01.003 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:28:01.003 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:28:05.922 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:28:05.922 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:28:07.645 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:28:07.646 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:30:42.977 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:30:42.978 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:30:55.499 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:30:55.499 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:31:02.764 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:31:02.764 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:31:20.518 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:31:20.518 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:31:31.607 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:31:31.608 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:31:32.680 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:31:32.680 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:34:46.190 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 2026-01-06 15:00:00
2026-01-07 13:34:55.741 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 2026-01-06 15:00:00
2026-01-07 13:35:12.510 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:35:12.510 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:35:33.516 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:35:33.517 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:35:45.450 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:35:45.451 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:35:49.552 | NQH6.CME/MNQH6.CME [C][M] 1 Min #9 | Trade Window graphics updated.
2026-01-07 13:35:49.552 | ESH6.CME/MESH6.CME[M] #2 | Trade Window graphics updated.
2026-01-07 13:50:26.706 | NQH6.CME/MNQH6.CME [C][M] 500 Volume #9 | Reloading chart.
2026-01-07 13:50:27.348 | NQH6.CME/MNQH6.CME [C][M] 500 Volume #9 | StartDateTimeForLoadingOrderFills: 2026-01-06 15:00:00
2026-01-07 13:50:27.443 | NQH6.CME/MNQH6.CME [C][M] 500 Volume #9 | Chart data loading complete.
2026-01-07 14:15:41.195 | File >> Disconnect selected.
2026-01-07 14:15:41.203 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-01-07 14:15:41.203 | DTC Client socket (1) | CloseSocket call.
2026-01-07 14:15:41.203 | DTC Client socket (1) | Max send buffers used during socket life: 3
2026-01-07 14:15:41.203 | DTC Client socket (1) | Max send buffer size during socket life: 406
2026-01-07 14:15:41.204 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-01-07 14:15:41.204 | Denali Data Feed | Waiting for socket receive thread to end
2026-01-07 14:15:41.204 | DTC Client socket (2) | CloseSocket call.
2026-01-07 14:15:41.204 | Denali Data Feed | Disconnected from the server.
2026-01-07 14:15:41.204 | Rithmic Direct - DTC | Disconnected.
2026-01-07 14:15:41.204 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-01-07 14:15:41.266 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-01-07 14:15:41.266 | DTC Client socket (2) | Closed.
2026-01-07 14:15:41.289 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-01-07 14:15:41.289 | DTC Client socket (1) | Closed.
[2026-01-07 22:22:32]
John - SC Support - Posts: 48342
That is the Message Log. We need the Trade Service Log. Follow these instructions:
Support Board Posting Information: Providing Lines From Trade Service Log
