Date/Time: Thu, 26 Nov 2026 04:11:47 +0000
MDI Virtual Space - Keyboard Shortcuts for Navigation?
View Count: 527
[2026-01-07 02:57:49]
gcUserStudies - Posts: 146
I’ve been exploring the new MDI Virtual Space feature and it’s fantastic for organizing multiple charts across a larger workspace.
Quick question: Are there currently any keyboard shortcuts available to quickly navigate or scroll between different areas of the virtual space?
For example, hotkeys to jump to specific quadrants and/or have saved scroll positions you can quickly switch between. If not this would be a great addition. Example would be having some charts out of view or a set of charts in a certain position within the virtual space that you could jump to and then back to your main view if that makes sense.
Thanks!
[2026-01-07 07:59:10]
Sierra_Chart Engineering - Posts: 25489
No not yet. But what does exist is this option:
General Settings Window: Scroll Virtual Space to Show MDI Window on Activation (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings)
You can jump quickly to a chart with the MDI tabs, or by selecting a chart from the CW menu and the virtual space will be automatically scrolled so the chart goes to the top left.
Date Time Of Last Edit: 2026-01-07 08:00:27
[2026-04-20 17:42:32]
Anders Dybdahl - Posts: 26
Adding a keyboard shortcut, when pressed and held, enables the scrolling of the virtual space with the mouse scrollwheel!! That I would like very much :)
Regards Anders
