Date/Time: Tue, 27 Oct 2026 17:54:24 +0000
Limit + Stop Limit orders (Fill Incorrectly)
View Count: 361
| [2026-01-06 17:35:37] |
| User39666244 - Posts: 3 |
I am using Acsil, to place automated orders I am trading MNQ. I am trading live and I noticed something very bizarre. My stop limit orders and my limit orders get filled but they get filled about 20 points away from the actual price on the chart. Another thing that is weird on the chart it says I am 20 points out of profit then when the order goes into profit about 20 points to 30 and I close the order I am still at a loss. It is not a connection issue or a commission issue because I only traded with one contract. I opened a trade and closed it immediately and lost about 40 to 50 points.
| [2026-01-06 18:00:39] |
| John - SC Support - Posts: 48342 |
You do not have any exchanges active for the CME Group, so your charts are showing the Delayed Streaming Data, which is 10 minutes and 10 seconds behind the actual market. You can activate the exchange(s) for the CME Group at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-06 18:38:13] |
Can you tell me the absolute best package for MMQ + MES, data streaming for live data?
| [2026-01-06 20:40:12] |
It depends on what you need. For the packages, refer to the following: Description of Service Packages and Pricing For the data, refer to the following: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
