Date/Time: Wed, 25 Nov 2026 22:08:28 +0000
trading evaluator - delayed (limits)
View Count: 294
[2026-01-05 20:15:43]
User30743 - Posts: 399
hello i started using trading evaluator, but i cannot find how to set up limit psition higher then 8. Can you pl send me a link?
[2026-01-05 22:39:28]
If you have not specifically setup limits, then you should not be limited. To check this, follow the instructions at the following link through Step #3:
Simulated Futures Trading Service: Margin Requirement Adjustments
Then select the "Symbol/Product Limits" tab and see if you have a limit set in there.
We wonder if you have the following option setup within your Sierra Chart software itself:
Global Symbol Settings: Use Global Trade Position Limit (Global Settings >> Symbol Settings)
And there is also a position limit per symbol in the symbol settings, so check the specific symbol you are having an issue for in the Symbol Settings as well.
