Date/Time: Sat, 18 May 2024 06:48:35 +0000
Volume by price TradeDom
View Count: 828
[2014-10-20 14:01:07] |
EthanC - Posts: 44 |
Hi, Is there a way to remove the volume histograms and only display the cumulative volume on the TradeDom? Thanks. |
[2014-10-20 17:49:35] |
Yes. There is an option in the Volume by Price Input settings to display the volume profile as an outline only.
