Date/Time: Sat, 18 May 2024 03:52:45 +0000
Number Study repeating the same value
View Count: 908
[2014-10-20 13:48:26] |
User787778 - Posts: 139 |
My number bar study is repeating the same value across different values. I have attached a file |
Number Bar issue 20 Oct 2014.docx - Attached On 2014-10-20 13:48:12 UTC - Size: 73.73 KB - 337 views |
[2014-10-20 14:51:47] |
Please respond
[2014-10-20 15:37:21] |
Please let me know when you will respond. I cant trade.
[2014-10-20 16:58:11] |
We see you are using Rithmic. Who is your broker? Also, we cannot accept the image that you attached. We do not accept those types of files. Only provide us an image by using these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-20 17:14:27] |
I use AMP with Rithmic. Is there a better trade service?
Attachment Deleted. ESZ4-CME [M] Rev. 5t #9 2014-10-20 12_12_27.601.png / V - Attached On 2014-10-20 17:13:12 UTC - Size: 92.54 KB - 357 views |
[2014-10-20 19:21:33] |
We did not realize you are using the Sierra Chart Real-time and Historical Exchange Data Feed. Follow the instructions here to use a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php It appears you are not and this is the reason for the problem. It is not related to Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-20 19:21:49
