Date/Time: Wed, 25 Nov 2026 22:08:27 +0000
SC Main UI Scrollbar *STILL* 'gone' missing (on all available download’able versions) ...
View Count: 473
| [2026-01-04 16:40:57] |
| Rainer - Posts: 112 |
ver 2852 - Strange Chart-Headers in Main-UI and *still* missing main-UI Scrollbars (see pic) ver 2829 - StrangeColor Chart-Headers in Main-UI and *still* missing main-UI Scrollbars (see pic) ver 2813 - Normal Chart-Headers in Main-UI BUT *still* missing main-UI Scrollbars (see pic) … with’ and all earlier versions = “no longer available for download” (regardless). *Detached Windows/Charts = work fine (as per usual)* ... "but" no Scrollbar in Main SC UI* (see pics) **No changes were made to SC’s settings … only just downloaded regular ‘current’ update and ‘saga began'** Current OS: Windows 10 LTSC 2021, multi-Monitors, (OS last updated: DEC 20, 2025) SC last updated: same day’ Dec 20, 2025 with ‘Everything’ working normal & OK Main UI scrollbars; *BUT* updated SC +4hrs ago = and all of a sudden *missing* Main UI scrollbars’ and the 'strange' above (see pics). note: Have hundreds of Charts in SC Main-UI (on many vertical-scroll pages), *but* can’t access/view ‘as scrollbar is missing’, and no way to ‘invoke’ (view, scroll) vertical Main-UI pages regardless of any tweaks/changes to/in UI, not even ‘moving’ charts to edges of UI (which normally would invoke auto-show the scrollbar) etc. …. Global Settings ver 2852 screenshots also attached. Date Time Of Last Edit: 2026-01-05 05:34:53
| [2026-01-04 16:42:28] |
due to 3 picture limit, here is Global Settings ver 2852 pic ....
Date Time Of Last Edit: 2026-01-05 05:35:59
| [2026-01-05 08:45:46] |
| Sierra_Chart Engineering - Posts: 25483 |
What you are looking for is called the MDI virtual space and this is the option for it: General Settings Window: Enable MDI Window Virtual Space (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings) You need to set it to Yes and also set the percentage. We would recommend using at least 300% but you can make that all the way up to 1000%. This can only be used in newer versions of Sierra Chart. You will need to have version 2852, or later. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-05 09:02:49
