Date/Time: Wed, 25 Nov 2026 22:08:06 +0000
DOM does not show volume data at different prices
View Count: 581
[2025-12-31 20:02:41]
User794005 - Posts: 51
Hi. Is there a reason why i do not see volume at different prices? Please refer to picture attached. Is it because i have not activated MBO? Currently i pay for the number 11 Integrated Advanced services (also attached as picture).
imageScreenshot 2025-12-31 at 2.58.20 PM.png / V - Attached On 2025-12-31 19:59:18 UTC - Size: 366.37 KB - 302 views
imageScreenshot 2025-12-31 at 3.00.41 PM.png / V - Attached On 2025-12-31 20:02:22 UTC - Size: 212.99 KB - 281 views
[2026-01-01 17:40:51]
You have the "U.S. Equities Consolidated Tape" exchange active. This exchange does not include the Market Depth data. Refer to the following:
US Stock/Equities Consolidated Tape Data Feed
We do have Market Depth data for the NASDAQ TotalView data. Refer to the following:
Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes
You can use a combination of these two exchanges to get the Volume/Price data from the U.S. Equities Consolidated Tape and the Market Depth from the NASDAQ TotalView. Refer to the following:
Denali Exchange Data Feed: U.S. Equities Consolidated Tape with NASDAQ TotalView
[2026-01-02 16:31:23]
Thanks for sharing these documents. I followed the steps for "Denali Exchange Data Feed: U.S. Equities Consolidated Tape with NASDAQ TotalView" link. I added the "_MBO" at the end of each symbol and also added the symbol in the symbol settings page (attached picture).
Problem #1: I am having some problems that do not have a pattern to it. Some symbols load with the "_MBO" extension while some do not (attached picture). You can see the sumbol 'ASML_MBO' does not load for some reason but the 'AVGO_MBP' for exmaple, loads completely fine.
Problem #2: Even when AVGO_MBO loads completely fine, it does not show orders or data in the DOM chart on the very right.
I am doing something wrong here please guide me.
imageScreenshot 2026-01-02 at 11.25.35 AM.png / V - Attached On 2026-01-02 16:25:58 UTC - Size: 209.53 KB - 272 views
imageScreenshot 2026-01-02 at 11.28.33 AM.png / V - Attached On 2026-01-02 16:28:44 UTC - Size: 373.98 KB - 253 views
imageScreenshot 2026-01-02 at 11.29.39 AM.png / V - Attached On 2026-01-02 16:29:48 UTC - Size: 589.31 KB - 267 views
[2026-01-02 18:22:17]
In order to get the data using the _MBO suffix, you need to have both the "U.S. Equities Consolidated Tape" and the "NASDAQ TotalView" exchanges active. Right now, you just have the "U.S. Equities Consolidated Tape" active.
To activate the "NASDAQ TotalView", follow these instructions:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
[2026-01-02 22:52:57]
If i activate "NASDAQ TotalView US stock data", do i get all the stocks i previously had access to from "US Equities Consolidated Tape" or do i need both? It sayson "NASDAQ TotalView US stock data" that all US equities are included.
Date Time Of Last Edit: 2026-01-02 22:54:50
imageScreenshot 2026-01-02 at 5.53.36 PM.png / V - Attached On 2026-01-02 22:54:11 UTC - Size: 131.53 KB - 262 views
[2026-01-03 02:37:05]
I activated the "NASDAQ TotalView US stock data" that includes MBO data.
Question: If i use "-NQTV" at the end of each symbol instead of "_MBO", will that work the same and give me the DOM data?
[2026-01-03 04:26:15]
Yes:
However, the trading volumes will be lower.
Yes you will still have market depth data with this:
[2026-01-05 15:29:57]
Also refer to the links given in Post #2 for the 3 different options.
