Date/Time: Wed, 25 Nov 2026 22:08:19 +0000
BUG P&L is wrong
View Count: 330
| [2025-12-31 14:15:04] |
| TopGunTrader - Posts: 313 |
Hi, P&L always seems wrong for some reason. As you can see in this pic account ending in 36 is up $15 this is in Jigsaws Positions window and is accurate based on trade results and my main account is up about the same fills can be a few ticks off. Sierra shows -28.25P down. Date Time Of Last Edit: 2025-12-31 15:27:20
| [2025-12-31 16:04:09] |
Did a small trade $5 profit last one Sierra shows 5p less than before.
| [2025-12-31 17:04:36] |
| Sierra_Chart Engineering - Posts: 25483 |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
