Date/Time: Wed, 25 Nov 2026 22:08:25 +0000
Default Chart Settings For New Charts - Region Data lines
View Count: 454
| [2025-12-31 06:13:12] |
| Alexander - Posts: 18 |
Can I make the Region Data lines to be hidden by default when I open a new chart?
| [2025-12-31 16:32:43] |
| Sierra_Chart Engineering - Posts: 25483 |
Yes by using a chart template: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-02 09:17:11] |
I did everything exactly according Using Chart Templates, the region lines on the saved template were set to hidden. A new intraday chart opens with the parameters saved in the template, but all region lines are set to visible. I have version 2848 64-bit, Windows 11. |
| [2026-01-02 09:20:39] |
Should not be any problem with this. Go to the chart that has the Region Data Lines hidden, and then select Chart >> Duplicate Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
