Date/Time: Wed, 25 Nov 2026 21:56:11 +0000
DOM - how to remove green/red dash at price level
View Count: 531
| [2025-12-29 19:03:27] |
| User731823 - Posts: 4 |
Hello, any idea how to deactivate the red dash at price 15"22 and green dash at price 15"21 (screenshot below)? Thank you. https://www.sierrachart.com/image.php?Image=176692881638.png |
| [2025-12-29 19:05:21] |
Most likely this is the "Bid and Ask Lines". Select "Chart >> Show Bid and Ask Lines" to toggle these on/off. Refer to the following: Chart Menu: Show Bid and Ask Lines (Chart menu) If that does not do it, then check if you have the "DOM Graph" on. Refer to the following for this: Chart Settings: Draw DOM Graph On Chart (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-29 21:32:42] |
It was the Chart >> Show Bid and Ask Lines. Thanks a lot for help. |
