Date/Time: Wed, 25 Nov 2026 21:56:07 +0000
[Programming Help] - How can a DataColor array be reset in ACSIL
View Count: 637
| [2025-12-26 15:50:53] |
| curious16 - Posts: 48 |
I would like to set and unset using the DataColor array depending on whether a study links to another study that has, or does not have, per-bar color data. It is straightforward to initialize sc.Subgraph[k].DataColor by assigning any color value to the first element such as sc.Subgraph[k].DataColor[0] = 0; However, if this subgraph is later changed to a source without per-bar color data, the subgraph anyway keeps using the DataColor array. This requires to supply a constant value to each element of the DataColor array if it ever is initialised. I tried using sc.Subgraph[k].DataColor.ResetMembers() to reset the array. This looked fine in the debugger immediately after the call, but the DataColor array was subsequently reallocated. What is the purpose of the ResetMembers() method? How can use of the DataColor array be reset in ACSIL? |
| [2025-12-27 16:54:17] |
| Tony - Posts: 738 |
I am not sure if I understand your question correctly, sc.Subgraph[k].DataColor[0] would just set the color of sc.Subgraph[k] at first bar(index) on the far left, you still need to set the color of each index after that? Date Time Of Last Edit: 2025-12-28 03:35:12
| [2025-12-27 19:10:43] |
Sorry for not explaining this more clearly. Of course all bar indices need to be set when DataColor is initialized and used. When you first initialize a subgraph, the associated DataColor array is unset, and the color of each point on the subgraph is defined either by PrimaryColor or (if SecondaryColor is used) by SecondaryColor. If you check sc.Subgraph[k].DataColor.GetArraySize() in this uninitialized state, you get array size zero. To start using the DataColor array, you set at least one element (typically that is DataColor[0] but it could be any element). This initializes the DataColor array and maintains it at the same size as the Subgraphs in the study. As soon as the DataColor array is initialized, it is used for all points while PrimaryColor & SecondaryColor are ignored. This is all perfectly fine as long as you want to use DataColor and have per-point color data. The problem arises when you change the source of the Subgraph from one that has DataColor information to another one that does not. What you would like to do in this situation is to unset (de-allocate) the DataColor array and revert back to using PrimaryColor & SecondaryColor. However, I did not find a way to do that. A full redraw and reload of the study did not work. I tried to call the DataColor.ResetMembers() method and checked in the debugger. Immediately after calling this, the size of DataColor shrunk to zero, but it subsequently was again established at the previous size. The only thing that worked is to close and reopen the chartbook with this study which obviously is not a desirable scenario. There is another place where SC stores the information whether the DataColor array associated to a subgraph was initialized, and this information seems not to be reset when the ResetMembers() method is called. It would be helpful if the ResetMembers() method was really switching back to using the standard PrimaryColor & SecondaryColor properties. |
| [2025-12-27 20:13:15] |
| Sierra_Chart Engineering - Posts: 25483 |
What you want to do is inherently unsupported. Once the Subgraph DataColor array starts to be used, it cannot be unused unless the study is removed from the chart and added again, which would effectively happen when you close the Chartbook and reopen it.We can accommodate what you want to do. We could add a function like this: sc.ClearSubgraphDataColorArray (int SubgraphIndex) function to do what you want. ResetMembers does do exactly what it says. It resets the members of a Array Wrapper class but this is just an isolated array reference class. It does not actually disable the use of an array altogether. It is not meant for a custom study to be calling this. You will not see anywhere in Sierra Chart custom study functions any call to this function. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-27 20:14:19
| [2025-12-27 20:28:47] |
Thank you for clarifying. I am glad that it is now clear what I tried to achieve. As I suspected, the current implementation of SC does not have this option to reset the DataColor array once it has been allocated. If you could add a sc.ClearSubgraphDataColorArray(int SubgraphIndex) function that would indeed be helpful.
| [2025-12-27 20:30:48] |
Yes we will work on adding that function this week.
