Date/Time: Wed, 25 Nov 2026 22:08:22 +0000
Numbers Bars not showing
View Count: 1029
| [2025-12-24 07:45:22] |
| User495734 - Posts: 48 |
Hi Sierra, I am currently on Package 11 which should include the numbers bars footprint chart. Am using a blank tick chart but cannot see any of the bars. Could you let me know what might be the issue? |
Attachment Deleted. |
| [2025-12-24 08:29:00] |
| Sierra_Chart Engineering - Posts: 25483 |
Do you see the chart bars when you remove the Numbers Bar study?
| [2025-12-24 08:42:08] |
Yes, the charts appear again after removed. I've tried changing the background color - dont think thats the issue
| [2025-12-24 15:38:40] |
We want you to restart Sierra Chart. Also update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-26 03:42:30] |
Still doesn't seem to work. I'll try one more time. Just to check I dont need package 12 for numbers bars right? |
| [2025-12-26 06:26:34] |
No you do not need Service Package 12. We want you to open a new Intraday chart for the symbol, and add the Numbers Bars study. Do you see the study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-30 06:59:43] |
Hi Sierra, I've managed to open up a fresh chart, but when the numbers do not see to be working and keep showing as X or l, what settings do I need to change? More specifically when I change the column 1 numbers bar from volume to bid x ask vol the numbers disappear Date Time Of Last Edit: 2025-12-30 07:29:27
| [2025-12-30 16:56:12] |
Change the scaling: Numbers Bars: Scaling a Numbers Bars Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-30 19:12:07] |
Also check the Chart Values Scale Text Color: Graphics Settings: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-31 16:20:58] |
Regarding post #7, let us know if the problem is now resolved.
| [2026-01-02 07:11:44] |
seems to work for now. thank you!
