Date/Time: Wed, 25 Nov 2026 21:56:25 +0000
How to Create a Standalone Cumulative Delta Bars Volume Chart?
View Count: 2043
| [2025-12-23 12:50:46] |
| User708340 - Posts: 21 |
Hi SC support, I’m looking to display cumulative delta bars volume as a standalone chart in Sierra Chart. I know that after adding the cumulative delta volume indicator, a new panel appears below the ES chart. However, I need the cumulative delta bars volume to be in its own standalone chart—not just as a sub-panel. I want to use this standalone cumulative delta bars volume chart # as an input for another indicator. Is there a way to achieve this in Sierra Chart? Please share steps to create a standalone chart for cumulative delta bars volume Any help or suggestions would be greatly appreciated! |
| [2025-12-23 15:49:58] |
The general way to do what you want is to set the option for "Display as Main Price Graph" for that study. Refer to the following: Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph But the fact that you want to use the Cumulative Delta Bars as an Input for another study does not require that it is set as the Main Price Graph. If you let us know how you are wanting to use that data in another study, then we can point you to the proper information for this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
