Date/Time: Tue, 20 Oct 2026 18:29:42 +0000
Trading Evaluator Questions
View Count: 404
[2025-12-22 16:36:32]
User993067 - Posts: 200
Is there a link to set up the trading evaluator? or must this be done by 3rd party (prop) firm?...ie can i set it up myself and trade in the evaluator for a set period to show a track record?
What about replay in the evaluator?....if im trading in the evaluator all day and want to replay a session...how does that work?...do i have to use my broker feed on sim for replay? and if so how does that work if that feed received no data to replay because I was logged into the evaluator?
[2025-12-22 18:30:33]
John - SC Support - Posts: 48273
You can setup the "Trading Evaluator" for your own use. Refer to the following:
Simulated Futures Trading Service: Setup Instructions
You can run a replay in the "Trading Evaluator" and use the built-in Simulation Mode for that replay.
You can not use your broker data feed with the Trading Evaluator, as connecting to the Trading Evaluator takes up the connection. If you are getting your data from your broker, then you can use the "Trading Evaluator - Delayed" as you would be getting the delayed data feed from us.
But you do have the "NYMEX with Market Depth for Non-Professional Trading Accounts" setup with our Denali Exchange Data Feed, so you would be using that data with the Trading Evaluator.
