Date/Time: Wed, 08 May 2024 15:07:21 +0000
studycllct file doesn't show up data files folder
View Count: 880
[2014-10-19 00:53:38] |
User15903 - Posts: 3 |
hi everyone! I have followed the instructions on how to use studycllct files. According to the instructions, i need to save the studycllct data folder first. When doing so, when i clicked on select to save it on the data files folder, the studycllct file does not show up. Can somebody please help me with this. |
[2014-10-19 01:01:55] |
Sawtooth - Posts: 3993 |
Create a study collection by pressing Save, or Save Single, below the Studies to Graph list. It will put the file in the \Data folder. Go to Analysis in the menu to select it. |
[2014-10-19 02:30:20] |
So you want to use a study collection file provided by someone else or posted here on the Support Board?
