Date/Time: Sat, 18 May 2024 06:48:39 +0000
Plot Real Price on chart when a Study is set as the Main Price Graph
View Count: 813
[2014-10-18 18:49:26] |
ycomp - Posts: 277 |
If I set a Study as the main price graph, is there any way I can plot also on the chart the original data series? as candles, or high/low.. or even just plot some kind of study that will display the high and low values of the original series? I just would like to be able to see on the chart where the real price is also |
[2014-10-21 04:03:00] |
There is no straightforward way to do this that we can think of. One thing you can do, is instead of making the study display as the main price graph, just set it to display in Chart Region 1 and use an independent scale. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
