Date/Time: Wed, 25 Nov 2026 21:56:21 +0000
How to make price graph ALWAYS aligned to the right side of the chart?
View Count: 375
| [2025-12-19 13:51:39] |
| User134516 - Posts: 5 |
When price data are insufficient to fill all the chart window, the price graph is always aligned to the left side of the chart. And current price bar can be located literally anywhere in the chart, depending on how much data has been downloaded. It is possible to make the new bar to be drawn always at the right side of the chart? Thanks for help. |
| [2025-12-19 20:58:59] |
| Sierra_Chart Engineering - Posts: 25483 |
This is only possible by increasing the chart bar spacing so that the rightmost bar, is at the right side of the chart: Working With Charts: Changing Bar Spacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
