Date/Time: Wed, 25 Nov 2026 21:56:14 +0000
Number Bars – Ask Imbalances Not Displaying (Bid Imbalances Only)
View Count: 823
[2025-12-16 17:25:45]
User877866 - Posts: 35
Hello Support,
I’m having an issue with Number Bars / Volume Imbalance where only BID imbalances are displaying, and ASK imbalances are not appearing at all, even in conditions where they should clearly be present.
Context / Setup:
Chart Type: Number Bars
I am using Bid/Ask Volume Imbalance
Data feed and symbol are confirmed correct (liquid NASDAQ stocks with heavy ask-side execution)
Bid imbalances are plotting normally
Ask imbalances do not plot under any conditions
What I’ve verified already:
Ask-side imbalance thresholds are enabled and set correctly (not zeroed or filtered out)
Bid and Ask settings are symmetric (same imbalance method, same percentage / volume thresholds)
No session filters or time filters are restricting ask data
Color settings are visible (not transparent or matching background)
Chart is receiving real-time bid/ask trade data (Time & Sales confirms ask executions)
Expected behavior:
Ask imbalances should plot when ask volume exceeds bid volume by the configured imbalance ratio or volume threshold
Both bid and ask imbalances should appear independently based on execution flow
Observed behavior:
Only bid imbalances display
Ask imbalances never appear, even during obvious aggressive buying (market orders lifting offers)
Request:
Please confirm if there are any known conditions, settings, or limitations that would cause ask imbalances to be suppressed while bid imbalances still display
If possible, I’d appreciate a checklist of exact settings required for ask imbalances to render in Number Bars
Let me know if this could be related to:
Trade classification
Exchange-specific data
Calculation method (Diagonal vs Horizontal)
If needed, I can provide:
Chartbook
Study settings screenshots
Replay example where ask-side execution is visible in Time & Sales but not reflected in Number Bars
Thanks for your help.
[2025-12-16 18:21:40]
What study(ies) are you using to display the Imbalance and how are you setting it(them) up?
[2025-12-16 21:40:34]
can i send u the study?
[2025-12-16 21:45:01]
If you are using a custom study, then this is not something we can help with.
If you programmed the study yourself, then you are welcome to ask the community for help. We do not give Programming Help as part of our Support.
[2025-12-16 21:51:46]
I used no code, i used a config settings of the Number BARS using the native settings
[2025-12-17 15:05:33]
Please get us the chart by following these instructions:
[2025-12-17 15:18:18]
see attached
attachmentFootprint 12.16.25 (100k min imbalance only).StdyCollct - Attached On 2025-12-17 15:17:46 UTC - Size: 55.31 KB - 162 views
[2025-12-17 18:15:55]
The reason you are only seeing a colored background on the Bid side is that you have the color for the "Column 1 Range 3 Up Color" set to black. Therefore, there is no coloring for the Ask side. You need to set that to a color you want to view, just like you did for the Bid side with the orange color in "Column 1 Range 3 Down Color".
