Date/Time: Wed, 25 Nov 2026 21:56:22 +0000
Volume Profile settings
View Count: 341
| [2025-12-16 16:56:29] |
| mesapeti - Posts: 5 |
Hello support, I tried everything but cannot hide the connections between different sessions profiles. Is there a solution to hide them or what can i do? I did not find any input to hide them! I would like to see it as on the 2nd pic as TradingVew shows! Thanks! Best regards, |
| [2025-12-16 16:57:21] |
You need to change the "Draw Style" for those items to "Dash". Refer to the following: Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
