Date/Time: Wed, 25 Nov 2026 21:56:07 +0000
NYSE Composite Advancing Issues - Declining Issues Difference
View Count: 316
| [2025-12-16 15:55:54] |
| User466224 - Posts: 1 |
Thank you for the feedback, I have another question about $ADDC from ThinkorSwims platform. Does Sierra have an equivalent ticker to $ADDC from ToS? ADDC on ToS is NYSE Composite Advancing Issues - Declining Issues Difference. Just wondering if that is chartable, and if so which service package I would need to cover it. A friend told me I may need US Equitees feed then I can search for ADDC w/ no $ and I should be able to find it. |
| [2025-12-16 17:25:59] |
This is part of our "Market Statistics" offering. For NYSE, the symbol is "NISS-NYSE". Refer to the following: Sierra Chart Market Statistics This data is available with any package. But, depending on the "Current Selected Service" you are connected to, you may not have direct access to these items in that installation of Sierra Chart. If the "Market Statistics" options are not showing in the "File >> Find Symbol", then the easiest solution is to install a second Sierra Chart and leave the "Current Selected Service" as "SC Data". You will then be able to get those statistics in that installation. Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
