Date/Time: Wed, 25 Nov 2026 21:46:02 +0000
SPY
View Count: 417
| [2025-12-15 17:59:42] |
| User575399 - Posts: 351 |
Hello, can I JUST have SPY ( equities data) and not use FUTURES market depth data ? Or do I need CME data to run SPY data?
| [2025-12-15 18:32:45] |
You do not need any Futures data to get the U.S. Equities data. These are completely separate exchange options. For U.S. Equities, we have three data options. Refer to the following: US Stock/Equities Consolidated Tape Data Feed Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Denali Exchange Data Feed: U.S. Equities Consolidated Tape with NASDAQ TotalView When you are ready to activate an exchange, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-15 20:50:41] |
So, I have CME market depth and Denali feed. Do I need the Denali feed if I just want to have SPY data feed? Just want to be certain before canceling anything
| [2025-12-15 21:42:35] |
The Denali Exchange Data Feed is our general name for our data feed that has exchange options for multiple exchanges. The CME Group, U.S. Equities Consolidated Tape, and NASDAQ TotalView (among others) are some of the exchange options that are available as part of our Denali Exchange Data Feed. You need to determine what data you need. If you do not need the CME Group data, then you can cancel those exchanges. If you do need that data, then keep the exchanges, or make changes if you need to. The same for the other exchange options. You need to either cancel, keep, or activate the exchanges based on your needs. Keep in mind that if you "deactivate" an exchange, you will still get the data through the remainder of the current month, as the data is paid up front for the calendar month. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
