Date/Time: Wed, 25 Nov 2026 21:56:19 +0000
Configuration of draw anchored VWAP tool
View Count: 666
[2025-12-15 06:46:14]
TraderBake - Posts: 63
I tried to customize the "Draw anchored VWAP" tool the same way as it is possible with "Draw Volume Profile" tool.
It seems that it does not work.
How can I customize it?
[2025-12-15 16:42:28]
We do not yet have the documentation updated for the Drawn VWAP. So what you did is the correct method. You need to setup a Study Collection first and then set that in the configuration.
What exactly is not working properly?
[2025-12-16 05:49:06]
It doesnt matter which configuration I save as a study collection, at the end I always get this VWAP with dash draw style and one bottom band and one top band.
Changing drawstyle or number of bands has no effect.
image2025-12-16_064511.jpg / V - Attached On 2025-12-16 05:46:01 UTC - Size: 328.54 KB - 117 views
[2025-12-16 15:05:03]
You are not doing something correct in the setup. We just tested this ourselves to ensure there it is working properly and it is.
Are you saving the configuration after you select the Study Collection you want to use for the Drawn Anchored VWAP? And are you selecting the specific configuration you want to use prior to using the Drawn Anchored VWAP tool?
[2025-12-16 16:47:04]
Draw Anchored VWAP - Current Tool Config is not being applied
It is the same like in this video from an other user.
I have version 2813.
I have the vwap configured with draw volume profile now, this works for me.
[2025-12-16 18:08:07]
Sorry, apparently this has been fixed in the current Pre-Release, but not in the current Release version.
The current Pre-Release contains work we are doing with the MDI windows (the chart windows within the main Sierra Chart application). Normally we would not hesitate to tell you that you can update, but there are a lot of little things still being worked on in this regard, so it is not quite 100% yet. So it is your choice if you want to update or not.
