Date/Time: Tue, 17 Nov 2026 18:09:23 +0000
Wich sierra Chart package and data do I need for historical es
View Count: 502
| [2025-12-14 21:33:39] |
| User955871 - Posts: 16 |
Hello I do not want to trade I do not have a broker account My goal is only : -study and backtest es -view historical intraday tick data -use numbers bars (footprint) , volume profile , cvd , vwap I do not need order execution I do not want to connect to any broker I am non-professional trader Pleas tell me exactly -which sierra chart service package I should purchase -which data feed I should purchase so that I can view historical tick data for es ana test footprint charts Also pleas inform me about the approximate amount of historical tick data available thank you |
| [2025-12-14 21:53:59] |
| Sierra_Chart Engineering - Posts: 25432 |
What exchanges do you need historical data for?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-14 21:54:11
| [2025-12-15 00:32:40] |
Only CME exchange es futures only |
| [2025-12-15 16:20:10] |
| John - SC Support - Posts: 48555 |
For what you are describing, you would need to use our Delayed Streaming Data. This data acts like real-time data, so you can do everything you want with it, only the data is delayed from real-time by 10 minutes and 10 seconds for the CME Group. Refer to the following: Delayed Exchange Data Feed The Delayed Streaming Data and historical data is available with all packages, therefore you would want to be on the "Base Advanced" package. Refer to the following: Description of Service Packages and Pricing: Base Sierra Chart with Advanced Features (Service Package 5) In terms of historical data availability, refer to the following: Sierra Chart Historical Data Service: What is Included To change to a paid package, follow these instructions: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
