Date/Time: Wed, 25 Nov 2026 21:46:19 +0000
Changing Anchored VWAP default settings to 1SD
View Count: 514
[2025-12-14 20:26:09]
User855240 - Posts: 12
Greetings,
Is it possible to set the default standard deviation to 1 SD in the anchored VWAP tool instead of the 0.5 SD which comes in the original set up?
In other words once configured to a desired setting and thereafter each and every time I draw the anchored VWAP it will plot the VWAP and 1SD lines instead of the 0.5SD and the VWAP lines which it normally draws.
I have got the draw VWAP tool to a right click shortcut and now the idea is to quickly plot an anchored VWAP having the desired configuration at retracements to assess the direction of price. A toolbox or a control box with a defined configuration, or manually changing the settings each and every time an anchored VWAP is drawn is less efficient in terms of screen real estate, speed and effort due to repetitive mouse work to have a desired configuration.
Best,
Jay
Date Time Of Last Edit: 2025-12-15 09:15:31
[2025-12-15 16:15:40]
To set a Drawn VWAP as you want it, you need to setup a configuration that has what you want. In this case, the configuration is defined by a Study Collection. So you setup a study first for how you want the VWAP to show, save it as a Study Configuration, and then setup a configuration using that Study Collection.
Our apologies, but we do not have the documentation setup for this yet. Refer to the instructions for the "Drawn Volume by Price", as the Drawn VWAP follows the same concepts. You will find this here:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
You can setup a Control Bar button that will select the tool and configuration. Refer to the following:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
There is not a single Keyboard Shortcut option, but you can create Keyboard Shortcuts to select the drawing tool and another for the configuration, so you can do it with 2 keyboard shortcuts.
