Date/Time: Wed, 25 Nov 2026 21:46:19 +0000
Exporting Data
View Count: 427
[2025-12-13 18:02:13]
cmack1011 - Posts: 201
I've noted that when exporting data using "Export Bar and Study Data to Text File" that a significant portion does not transfer or transfer correctly, especially those values that are derived/percentage calculations (see screen shot). Are there any settings that I may need to apply to improve export? Thanks.
imageScreenshot 2025-12-13 at 11.46.42 AM.png / V - Attached On 2025-12-13 18:01:21 UTC - Size: 535.83 KB - 233 views
[2025-12-13 18:30:36]
Yes, check the Value Format setting of each of the studies:
Chart Studies: Settings and Inputs Tab >> Value Format
Date Time Of Last Edit: 2025-12-13 20:30:40
