Date/Time: Tue, 07 May 2024 14:54:26 +0000
Color bar Study Not displaying properly
View Count: 896
[2014-10-17 17:07:36] |
Handle - Posts: 36 |
Using v1198 I set up the color bar based upon above/below study and the study it is based upon is the Bid Ask ratio study. Bar colors remain only red and do not chage colr as they cross the zero line Have this same exact chart setting and graphic setting , etc on another machine with a SC instance of v1199 and the study works as designed. Updated the machine with v1198 to v1202. Same problem. I have double checked all the setting and inputs and verified that the chart is not affected by global graphic settings. Still bars do not change color based upon the action of the Bid Ask Ratio Study. Bar Color remains red |
[2014-10-18 04:04:33] |
Make sure the Color Bar study is located at the bottom of the list of studies in the Studies to Graph list.
