Date/Time: Wed, 25 Nov 2026 21:46:18 +0000
Replay Chart wont go back 30 days?
View Count: 361
| [2025-12-12 16:31:25] |
| User172061 - Posts: 36 |
Just a weird issue for me. If i try to replay a day more than 30 days ago, it basically wont, unless i go in and reconfigure my chart to have more than 30 days worth of data for all my charts. is this just how the replay function works? i leave it at 30 days because..well, honestly i dont even need more than 5 days worth of data on most of my charts and it speeds it up, going back a year or so would slow it way down. is there a workaround for this? to have it just download the data during replay and not while using the charts? or do i have to change it every time i want to switch from replay to live?
| [2025-12-12 16:44:41] |
Yes, this is exactly how the replay works. You must have the data already loaded in the chart for how far back you want to star the replay. For what you are wanting to do, you would need to load the data for the chart to replay. Or, an easier solution, would be to have a duplicate chart that has the large number of days loaded, and then hide that chart until you want to run the replay, and then run the replay on that chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-12 17:04:19] |
ooohhh the duplicate chart idea is genius! thanks!
