Date/Time: Wed, 25 Nov 2026 21:46:22 +0000
Connected & internet ok - but no data and not updating. Last data posted 630-6 am WCT
View Count: 397
| [2025-12-12 00:09:54] |
| User794190 - Posts: 28 |
I lost my global setting somehow. I reinstated them. But no data and no updating. Screen frozen at 630 -7 am this morning (west coast time, Thurs 12/11/2025). Using MarketProfile. 12/12/2025 - THIS PROBLEM HAS GONE AWAY. SIERRA WORKING PROPERLY NOW. Date Time Of Last Edit: 2025-12-12 16:42:36
| [2025-12-12 00:47:32] |
| Sierra_Chart Engineering - Posts: 25483 |
First update Sierra Chart to the current version. Instructions: Software Download: Fast Update Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-12 00:47:41
| [2025-12-12 17:20:19] |
We see the update in your message that everything is working now. If you are still having an issue, then let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
