Date/Time: Wed, 25 Nov 2026 21:56:24 +0000
Hide Window
View Count: 644
| [2025-12-11 16:28:43] |
| nicktrader - Posts: 817 |
In the past I had hidden some charts to activate them only when needed. Unfortunately, this was not possible in version 2829. After I updated to 2829 and started the program, all charts were visible. I set them back to “hidden,” but when I restarted the program, they were visible again. I am now back to 2813. |
| [2025-12-11 18:37:44] |
We are not able to reproduce this with version 2829. Please let us know how you have your windows setup when you hide the window and when you save the chartbook and restart. We want to know if you have the windows maximized in the main application, or if they are individual windows in the main application, or if the windows are detached. Also, make sure you are saving your Chartbook after you hide the windows and before you exit from Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-12 07:57:21] |
Pls see pic...
| [2025-12-12 17:50:55] |
| User719512 - Posts: 548 |
I am seeing this issue too after going to v2830 (happened on v2929 also). I even re-hid all windows in v2830, saved, closed, and when reopened...every window is open and none are hidden. Date Time Of Last Edit: 2025-12-12 17:51:08
| [2025-12-12 21:10:29] |
| Sierra_Chart Engineering - Posts: 25483 |
We are checking on this.
| [2025-12-12 21:34:44] |
Here is a chart book I just made in v2830. 4 charts. title bar/no title bar, hidden, not hidden. When I open this chart book, I see 4 charts when I should only see 2. Attaching here just in case something strange is happening with the version upgrades I have done from v2813, interim builds, then 2829 and 2830 and the chartbook metadata is somehow not as expected. |
Private File |
| [2025-12-12 22:18:10] |
This will be resolved in the next release.
| [2025-12-13 00:10:04] |
While fixing the above, can you also verify that saving and closing a chartbook with Minimized windows will reopen with those windows minimized? In v2830, my chart book test does not show the minimized window when reopened. The tabs are there, and you can Restore with the context menu. |
| [2025-12-13 00:42:42] |
In the next release, minimized windows will be in a restored/normal state. We are not going to support minimizing a window into the MDI client area. Thereafter, the functionality will work as documented here when minimizing: Notice: Solution to: Chart/Chartbook Tabs Visibility Issues, Portions of Chart Window Cut Off | Post: 431374 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-20 23:05:09] |
Use the latest prerelease. There are several minimize options now available. Including minimizing to the bottom of the MDI client area. But it is implemented differently than the operating system does it. See the latest post here: Notice: Solution to: Chart/Chartbook Tabs Visibility Issues, Portions of Chart Window Cut Off Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-20 23:05:20
