Date/Time: Wed, 01 May 2024 04:13:56 +0000
no symbols
View Count: 827
[2014-10-17 13:49:55] |
User162879 - Posts: 1 |
connect to server works, but no symbols for fxcm show up
[2014-10-17 15:51:30] |
Sierra Chart - Max - Posts: 5597 |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support |
[2014-10-17 18:11:38] |
Update the symbol settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings After that check to see if you have the symbols in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
