Date/Time: Wed, 25 Nov 2026 21:46:23 +0000
Montage not showing correct DPL
View Count: 347
| [2025-12-10 16:35:54] |
| User856350 - Posts: 46 |
right when an order fills for me a negative or positive number just appears on the montage redonmly and then closes redonmly when i exit but its not the correct trade and PNL that i traded. how can i fix this? thanks Paolo |
| [2025-12-10 16:59:40] |
| Sierra_Chart Engineering - Posts: 25483 |
Refer to this page: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-10 18:15:33] |
wow thats a lot of things to go through how do i navigate all of this seems very confusing is there another way?
| [2025-12-10 18:58:02] |
Yes. Follow these simplified steps: Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
