Date/Time: Wed, 25 Nov 2026 21:46:23 +0000
Numbers Bars – Missing Imbalance Highlighting Inputs
View Count: 503
| [2025-12-09 14:20:23] |
| User593995 - Posts: 1 |
ello, I am using Sierra Chart version 2813 (64-bit), Revision 54597. Inside the Numbers Bars study, I do NOT have the Inputs related to Imbalance / Diagonal Dominant AskVol BidVol coloring. There is no setting for: Imbalance Up Color Imbalance Down Color Diagonal Dominant AskVol BidVol Difference Imbalance Percentage Thresholds I only see basic background and range colors. I also added “Numbers Bars Calculated Values 2”, but it still does not provide any Imbalance settings in the main Numbers Bars study. Can you please tell me if this version (2813) does not support Imbalance Highlighting and whether I need to update or enable something? Thank you. |
| [2025-12-09 17:37:34] |
The particular items you are searching for do not exist in our Numbers Bars study. We are curious where you got that information from. As to the ability to show an imbalance in the Numbers Bars study, refer to the following: Numbers Bars: Display Ask/Bid Imbalance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
