Date/Time: Wed, 18 Nov 2026 09:39:25 +0000
Color Bar Based on Alert Condition - Cumulative Delta Bars - Volume Study
View Count: 630
[2025-12-09 01:44:13]
RadioDC - Posts: 31
I'm trying to get a visual alert on the main price graph (Using Numbers Bars) when the current main price graph bar closes higher and the bar on the study (Cumulative Delta Bars - Volume) closes showing negative delta.
This is the alert condition:
=C > O AND ID3.SG4 < ID3.SG1
ID3.SG4 is the Close of the CDBV study & ID3.SG1 is the Open.
I do not get any Syntax or other errors in the Message Log, however, there is no visual alert when a current main price graph bar closes higher and the CDBV study shows negative delta. I followed the steps in the, "Drawing Arrows/Text or Other Styles at the High or Low of Bars" in the Color Bar Based on Alert Condition Studies Reference.
Any help would be greatly appreciated.
Thanks - Dave
[2025-12-09 16:00:05]
You are not using the AND() function properly. Your formula should be the following:
=AND(C > O, ID3.SG4 < ID3.SG1)
Refer to the following:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#AND_Function
