Date/Time: Thu, 26 Nov 2026 03:41:26 +0000
Credits for text to speech
View Count: 712
| [2025-12-08 14:55:34] |
| User273277 - Posts: 145 |
I just tried creating a new text to speech file, and received a message in the logs about not enough credits. I don't recall this costing anything previously. Please advise.
| [2025-12-08 15:22:04] |
| Sierra_Chart Engineering - Posts: 25489 |
We will check on this.
| [2025-12-09 13:37:37] |
Today the wav files were created, but they are invalid. ie. pressing test produces a windows error ding. And the files don't play from Windows explorer, unlike the old wav files from a few months ago that were generated which work properly.
| [2025-12-11 03:27:27] |
Still not working today.
| [2025-12-11 05:38:30] |
The particular backend functionality, for this has been discontinued but we are working on a replacement. It should not take too long. We should have this ready in about two weeks we would expect. Please, use this alternative text to speech functionality where you can specify specific text to be played for each Alert Number, in the meantime: General Settings Window: Text to Play When This Alert Triggered (Global Settings >> General Settings >> Alerts >> Alert Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-12 03:05:22] |
The new speech generator is now released. You can generate speech here: https://www.sierrachart.com/UserControlPanel.php?page=TextToSpeech And from within Sierra Chart in the same place in Global Settings >> General Settings >> Alerts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-12 16:29:37] |
Thanks for getting this working again so quickly. However, this is a very abrupt voice with a much lower quality and lower pronunciation ability compared to the previous text to speech generator. It's a bit jarring having different voices speaking the alerts all day. A bit of an uncanny valley thing happening. Is there any way to have the TTS in the same voice as before? Date Time Of Last Edit: 2025-12-13 04:02:18
| [2026-03-25 14:48:21] |
We apologize for the delay. The service we were using in the background, is not really a service we want to use anymore. It is available but provides no longer any technical support. And it is also something we have to pay for, while that is not a problem, we have to periodically make payments and can forget about that. It is not something we want to be continuing to support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
