Date/Time: Wed, 08 May 2024 00:02:05 +0000
Cut multiple drawings - request
View Count: 841
[2014-10-17 11:54:22] |
User59042 - Posts: 22 |
Hello SCH team, every day I use tools as Horizontal Ray, Extending rectangle etc to draw my Support/Resistance levels. At the end of each day I have to cut them manually one by one so I can draw a new ones and still see the old ones for past days. I am finding way to make this process easier and faster. I see two options. 1) One way I see is allowing to set extension of those tools only for like day period or any other time period. So I can draw for instance extending rectangle and it ends based on my day's time setting. 2) I though about a tool like Vertical line which would cut multiple tools as if I draw it across them. Is there anyway to make this happen? Many traders definitely would find it helpful. Thanks |
[2014-10-17 22:50:48] |
There are no plans for this and we cannot offer help with this. We recommend developing a custom study using the Sierra Chart ACSIL to accomplish what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-17 22:51:04
