Date/Time: Wed, 25 Nov 2026 21:45:58 +0000
CME Historical Data
View Count: 1074
| [2025-12-06 20:46:45] |
| User449867 - Posts: 12 |
Hi I am trying to get 10 years of historical data on my daily and weekly ES chart but can only seem to download just over 5 years. I have tried to get the same data on my NQ chart but can only get the data back to 9th September 2019 I have managed to get data on my Eurex Bund Weekly going back to 2013 - I have used the same settings for both Eurex and CME products Is it possible to get data going back for the CME products? I have tried everything I can find on the support boards etc for this but have had no joy Many Thanks |
| [2025-12-06 21:20:44] |
| Sierra_Chart Engineering - Posts: 25483 |
Since you are using Rithmic, there is a limit to the number of years due to a single digit year in the symbols. You need to use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service And this is also explained very clearly here: Continuous Futures Contract Charts: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-06 21:24:52
| [2025-12-06 21:43:36] |
Thanks for the quick response Can I ask why the Eurex symbols allow me to get more data when they are going through Rithmic also? |
| [2025-12-06 21:45:53] |
This is because those symbols, have two or more digits for the year. All other Rithmic symbols, the most commonly used ones, use a single digit year.
| [2025-12-06 22:09:32] |
If I switched over to Teton with my broker for CME non pro fees - can I still connect to the Eurex exchange without Rithmic for the Data using denali - as I am only sim trading for now?
| [2025-12-08 00:06:25] |
Yes, when using Teton order routing, you have access to all of the EUREX symbols, and will receive the real-time data, and can do simulated trading. And you can also install multiple installations of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-08 00:06:47
