Date/Time: Wed, 25 Nov 2026 21:45:57 +0000
subgraph...auto-coloring
View Count: 579
| [2025-12-06 17:19:16] |
| more - Posts: 154 |
Hello, about cumulative delta bars-volume, in subgraphs, To color the up and down bars in different colors, independently from the main graph, what should I set to auto coloring? I saw this page, Chart Studies: Subgraphs Tab >> Auto Coloring but I can't do it. thanks
| [2025-12-07 18:59:59] |
| Sierra_Chart Engineering - Posts: 25483 |
Subgraph Auto Coloring is not supported when the Graph Draw Type is a chart bar type. It is only supported with individual Subgraphs like Line.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-07 19:00:16
| [2025-12-07 19:16:48] |
| more - Posts: 154 |
but I have seen some images/videos of people with the cumulative delta bars with colored candlestick bars (obviously sierrachart)
| [2025-12-07 19:35:13] |
| User708541 - Posts: 215 |
Maybe I'm misunderstanding the question but I think all you have to do is pick the colors you want in the Subgraph tab of the Study. You can have the delta candles in any color you want. You have your main price graph with Green Up candles and Red down candles and you want the Delta candles to be Blue for up and Pink for down, that's easily done through the settings in the Subgraph tab.
| [2025-12-08 08:55:07] |
| more - Posts: 154 |
I'm sorry,but maybe I'm doing something wrong. I attached an image
| [2025-12-08 16:35:58] |
To change the colors of the "Cumulative Delta Bars" you need to adjust the subgraph colors for the "Open/High/Low/Close" subgraphs. Refer to the following: Color Settings for Graph Draw Types: Candlestick Note that there is an option at the top of the Subgraphs Tab for "Use Chart Graphics Settings for Subgraph Colors". This will need to be unchecked to change the colors, but it is unchecked by default. Refer to the following: Chart Studies: Subgraphs Tab >> Use Chart Graphics Settings for Subgraph Colors For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
