Date/Time: Tue, 13 Oct 2026 16:20:54 +0000
Double click on Tab
View Count: 493
[2025-12-05 07:51:33]
nicktrader - Posts: 816
In version 2813 it was possible to maximize the chart by double click on the Tab.
In 2821 it don't work. Is it adjustable?
Many thanks
[2025-12-05 15:14:38]
John - SC Support - Posts: 48189
We will check into this.
[2025-12-05 17:21:14]
Sierra_Chart Engineering - Posts: 25161
We will add this functionality.
[2025-12-05 20:24:04]
This was already there, but we had to change the functionality because, it needed to be implemented differently with all of the changes.
[2025-12-06 07:06:48]
Okay, I always used this functionality...
[2026-06-22 01:17:36]
JPO - Posts: 7
I'm not sure if this thread completely relates to my issue, but maybe. In previous versions before I recently updated to 2913, I could have several charts/tabs custom-sized to be next to each other in various configurations, but then double click a tab to take it to full-screen, and then double-click again to go back. I used this all the time. Is there a comparable way to resize now, or will this functionality perhaps return? When I double-click a full-screen tab now, nothing happens, and then when I click the new "Minimize" button up top, it resizes to a very small window. Thank you.
***Edit: just realized I can click "Restore" up top, or right-click chart tab and click Restore from there. Leaving for anyone dealing with the same. Thanks.
Date Time Of Last Edit: 2026-06-22 01:23:26
[2026-06-22 18:10:46]
We are not certain what you are looking for that is not functioning in the recent releases. You can double-click a tab to maximize a window.
And with regards to the minimize option, refer to the following setting that controls how this now works:
General Settings Window: MDI Child Window Minimize Method (List) (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings)
We also recommend looking through the other settings in the section linked to above for other settings related to the new windows.
