Date/Time: Wed, 25 Nov 2026 21:35:58 +0000
lucid rythmic data
View Count: 3130
| [2025-12-05 00:44:43] |
| SurfTrader - Posts: 88 |
Hi Im trying to connect SC through Lucid prop using their rythmic data feed. I switched over and all my vharts on my chartbook are blank. When I reconnect it says historical intraday download data skipped. What am I doing wrong?
| [2025-12-05 14:59:20] |
Our best guess is that you did not update the symbols for your charts when you made a change. Each service uses a different symbology. With your chartbooks open, select "Edit >> Translate Symbols to Current Service". This will change the symbols in your charts to what is needed for Rithmic. If not the above, then check to make sure that you have entered the "Market Data" and "Historical Data" Username/Password on the "Global Settings >> Data/Trade Service Settings >> Main Settings" for the Rithmic service. You are not setup to get any data from us, so you have to get it from Rithmic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
