Date/Time: Sun, 19 May 2024 00:53:09 +0000
number format in new spreadsheet
View Count: 874
[2014-10-17 07:30:07] |
George Slezak - Posts: 36 |
I just downloaded the new version and my quote spreadsheet has quotes to 7 decimal places. Is there a way to set default as two decimal places, or a hot key for cell formats? or a column decimal place format? Redoing 100 cells one at a time is a pain. ALSO My old spreadsheet of quotes does not update in the new program. Looks like I need to create a new "quote spreadsheet" Also ##HD does not give quote column headings Date Time Of Last Edit: 2014-10-17 08:33:14
[2014-10-21 04:44:52] |
If you are using the New Spreadsheets, you can select cells and change the number format for them by selecting Spreadsheet >> Number Format. We need to check on the quote updating problem. We will add a command to set any existing Spreadsheet to function like a "Quote Spreadsheet". This will automatically display the header at the top. We will try to get this done in a few days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
