Date/Time: Wed, 25 Nov 2026 21:36:13 +0000
Denali-Rithmic connectivity
View Count: 384
[2025-12-04 10:35:50]
User518468 - Posts: 20
Hi everyone; I've heard that Rithmic can cause connectivity issues when used with Sierra Chart.
My question is: If I use Denali as the data feed, and only use Rithmic for order execution, would this help mitigate those problems?
If this hybrid setup is possible, I'm a bit unsure about the configuration steps.
Regarding the video below (if u can see it), can you tell me if the presenter is using Rithmic for both data and execution in his connection method, or if I can follow his steps to implement the Denali/Rithmic setup?
https://youtu.be/V3NhJ2KGbrQ?si=N9stD9QtYGCo74N5
[2025-12-04 15:20:20]
This will help with data issues, but you may still have issues with connetivity related to trade execution.
Yes, this is possible. It is specifically how Sierra Chart is setup. Refer to the following:
Denali Exchange Data Feed: Integration with Trading Services
The information they give is generally correct for connecting to Rithmic and using the Denali data. Here are the specific links to our documentation for the setups:
Rithmic Trading Platform Service: Setup Instructions
Keep in mind that in order to get the real-time CME Group data at the non-professional pricing, you need to have a live, funded, futures trading account. And you need to connect your Sierra Chart software to that account at least once a month for verification. Refer to the following:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
