Date/Time: Wed, 25 Nov 2026 21:36:01 +0000
Why the change on the interface?
View Count: 497
| [2025-12-04 04:50:34] |
| krypto101 - Posts: 36 |
Not to rant but I'm gonna rant. I don't get why the interface for settings changed, its uglier and harder to visually find settings. The legacy style was better to understand, you knew what was clickable, recognized drop lists, text fields were obvious etc. The current one just shows you a black background with lines and white text, like I'm supposed I'm playing an Atari game. Please bring back the classic settings style again. I attached an image of what I'm referring to below |
| [2025-12-04 05:01:34] |
| Sierra_Chart Engineering - Posts: 25483 |
Regarding Chart Settings, refer to: Settings Windows Interface: New Chart Settings Window This is taken as a compliment ( in the sense, that the interface is clean and efficient): its uglier
And actually, all of the colors and other appearance attributes are all very configurable. It is impressive what you can do with them. Whereas Microsoft, is locking you into just one simple plain interface. So the new Settings Windows are really the exact opposite of what you are saying. They really should become a standard for operating systems.And this really factually is untrue being there is search functionality, the settings are categorized according to the category they are in, and there are more categories: and harder to visually find settings
Refer to: Settings Windows Interface: Searching for Specific Settings Regarding drawing tool configuration/properties windows, those are still undergoing some development. There is some incremental improvements being made with those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-06 05:53:08
| [2025-12-04 06:01:35] |
We will update the Line Style list box in the new Drawing Tool Configuration/Properties window, to show the graphical line styles as previously. And we did already add the ability, to display the quick configuration buttons on the right side. It is controlled with this option: Global Settings >> Tool Settings >> General >> Show Quick Configuration Load Buttons as Permanent Buttons: Yes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-04 06:03:02
